VideoHelp.com Forum
  1. Member blutach's Avatar
    Finally, after a year of development, PgcEdit version 9.0 has been released. This is a major upgrade - the changes are so numerous they can't all be lised here. See What's new in PgcEdit v9.
    Thanks a million to r0lZ!
    Full information here.
    Regards
    Les
    Thanks for the great work.
    I have been using the PGCEdit for almost 2-3 years. Once I asked for some feature to be added
    (i.e. when you have multiple audio, and subtitles) for cut/paste of stream information when I was
    combining diff clips to make a new dvd.
    That is very handy. THere are lots of other useful stuff.
    It takes a while to learn to use this tool.
    I will try the new version soon.
  3. Member blutach's Avatar
    Version 9.1 has been released (small bugfix release).
    Thanks to r0lZ!
    Regards
    Changes from 9.0 to 9.1:
    9.1 (January 3, 2009)
      F. DVD -> Clear Useless Set GPRM Commands and Info -> Find Useless Set GPRM
         Commands were sometimes considering erroneously a GPRM as useless.  Clear
         Useless Set GPRM Commands and DVD -> Remove Useless Stuff were therefore
         dangerous to use, as they sometimes cleared a useful command.
      F. DVD -> Delete Last VTS produced an error when a PGC of the last VTS was
         selected when calling this function. The VTS was not properly deleted
         from disc.
      F. Preview -> Automatically Start Preview Playback produced an error. The menu
         worked as expected though, and the bug had no consequence.
      F. With the option "Allow tearoff menus" disabled, some entries in the main
         PgcEdit menu were not enabled when a DVD was loaded.
      F. Fixed the incorrect View -> Toolbar checkmark.
      E. Title -> Title Play Map Table: The hearers of the columns no longer scroll
         when using the scroll bar.
      F. A JumpSS from a VTSM to a menu in another VTS was not flagged as illegal.
      F. PUO Editor: PgcEdit was frozen after having pasted a value in the Input
         Value dialog.
      F. Trace: The trace was stopped and impossible to continue when the preview
         was enabled and the VOB files were missing.
      F. Domain Stream Attributes: The new Film/Camera flag was not disabled in
         read-only mode.
      F. Since the sources of PgcEdit are no longer publicly available, I've removed
         all references to the GPL license from the program.
      F. Fixed several small bugs.
    Les
  1. Replies: 11
    Last Post: 12th Mar 2011, 17:18
  2. Best ever 2009 Camcorders ever
    By Fary4u in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 22nd Jan 2010, 13:25
  3. Replies: 0
    Last Post: 13th Nov 2009, 11:47
  4. What antivirus do you use. 07/04/2009
    By G)-(OST in forum Computer
    Last Post: 6th Apr 2009, 15:50
