I have analog cable service with no cable box; the cable plugs directly into my DVD recorder that allows me to watch paid basic cable channels.
I have a DVD recorder with a tuner but the DVD recorder/playback function is broken. I'm considering buying a tunerless DVD recorder with VCR.
Can I daisy chain the broken DVD recorder with tuner, and the tunerless DVD recorder with VCR, and use the tuner in the broken DVD recorder to tape shows to the newer tunerless DVD recorder with VCR? Or will this not work? Or, should I just buy a DVD recorder with a tuner?
Thanks in advance for your comments.
Although the simplest solution would to buy a DVD recorder with a tuner, your idea will work.
Just connect the audio/video out of the "tunered" DVD recorder to one of the audio/video inputs of the tunerless DVD recorder/VHS combo. Set the DVD recorder/VHS combo to record from that input and you're in business.
can ImgBurn finalize DVDs recorded on broken Lite-On DVD recorder
By donlamb in forum DVD RippingReplies: 4Last Post: 16th Jun 2010, 16:53 -
Connect VCR/DVD Recorder to PC which has TV Tuner
By Butch1942 in forum Media Center PC / MediaCentersReplies: 1Last Post: 16th Feb 2009, 19:03 -
Not sure if I need a dvd + vcr recorder player with built in tuner or not
By zalman001 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 1st Oct 2008, 10:33 -
tuner in DVD recorder
By miki100 in forum Newbie / General discussionsReplies: 7Last Post: 3rd Sep 2008, 23:18 -
DVD Recorder Tuner
By jh76 in forum DVD & Blu-ray RecordersReplies: 10Last Post: 7th May 2008, 13:24
Statistics
Newest guides
Latest tool updates
New media comments
