Hi all.
Interleaved MPEG-2 file, trying to save it as a x264 video file in an avi or mkv container. It will work with anything but if i try to use a deinterlacing filter it works fine but soon as i set cropping in the filter it tells me "source image format is not acceptable"
any ideas?
After you crop the video, you must resize back to its original dimensions (Resize filter in VDub).
is there any way i can get around that? i would prefer if i could just crop the video and not have to resize it.
if i must resize it which method is the best? ive heard lancoz3 is good.
If you don't want it back to the original dimensions then at least crop it to a mod2, 4 or 16 boundary (which one depends on the codec). My guess is you have cropped to an odd number of pixels.
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 20:50 -
VirtualDub "format convert" audio filter - how do I use it?
By Jedi787Plus in forum AudioReplies: 0Last Post: 12th Sep 2009, 15:35 -
What are "Source" and "Transform" filters in MPC?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2008, 21:20 -
NAME="mplayerc.exe" FILTER="GRABMI_FILTER_PRIVACY"
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 7th Aug 2008, 15:40 -
"Filters" greyed out in VDubmod
By Captain Satellite in forum Newbie / General discussionsReplies: 5Last Post: 16th Aug 2007, 11:39
thanks
