Hi i'm interested to make Blu ray disk HD . I download a movie i thing it's HD file like H-264-avc Mpeg4
and this file mpeg4 i want to convert in blu ray disk. can you tell me how can i do this job ...which software
or how can i make a blue ray disk HD.
Another person with a "special" MKV that wants to play it on his blu-ray player...
For the sake of others reading this, since you didn't encode it yourself, chances are you don't know what AVC settings have been used to create it. (Beggars... err, downloaders can't be choosers...)
Yes, blu-ray does play AVC. But like MPEG-2 with DvD, it has to be encoded a certain way otherwise it's not compliant.
You can remux, hack, etc and you may get lucky with the right file and player. But if it wasn't encoded with blu-ray specs, chances are it won't work, or it will stutter, glitch, or just play wrong at best.
If it doesn't work on your blu-ray player after TsMuxeR, as Baldrick said, then your only choice is re-encoding. RipBot264 and MeGUI are the two free apps that come to mind.
There are some hack tricks floating around the 'Net, particularly with using BDEdit, (do a search, I won't help you here) but they too are minor league and aren't any guarantee either. Only re-encoding with the right spec is a guarantee.Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
Forgot to point out. If indeed you manage to "fix" this file and create the proper blu-ray structure using TsMuxeR (or even used BDedit) then you would need to burn onto a disc.
I recommend Imgburn (must be version 2.4 and above), like Baldrick mentioned. Here's how to burn a ready-made blu-ray structure onto a disc:
Tools -> Settings -> Write tab -> enable "DVD-RAM / BD-RE FastWrite"
Click OK
Now, in the intro interface, choose "Write files/folders to disc"
Options tab -> select UDF -> 2.50Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
Thanks PuzZLer, this worked perfectly for me: you have no idea how much this helped me in my bluray troubles..
-vhelp 5057
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 03:35 -
How do I make a Blu Ray disk from an MP4 or MP2 file?
By True Colors in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 04:26 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
Converting mkv file to whatever it takes to burn to a blu-ray disk.
By jwmghf in forum Video ConversionReplies: 6Last Post: 26th Sep 2009, 09:58
