I have encoded over an hours worth of home HD video with both TMPGEnc 4.0+ and the latest release of Badaboom to H264 in mp4 containers. The videos play back fine on my computer, but as soon as I view it on the xbox (either from a disc or a flash drive) the video starts just fine, but after a few seconds it starts to stutter (going at about 5fps) but the audio is fine.
Now if I pause the video or skip ahead the video is fine again for another few seconds and starts to stutter again.
I've set the bit rate at 4500kbps in each encode. I know that the xbox can handle that since I have downloaded videos at much higher bitrates than that and they all work fine.
Does anyone know where the problem may be?
Thanks in advance.
Have you ever had success playing such files on the xbox360 before ? ... I mean those you have created, not those you downloaded from other sources
If this is something new, then check your xbox360's firmware is updated beyond september 2007.
Ya I have the latest xbox update (NXE) and I play aplenty hidef content all the time. I download a few tv shows in HD every week and I never have any problems. The only thing I can think of is that the videos I'm converting are coming from an AVCHD source, which I can't see that as a problem since the output file should be 100% compatible, but maybe I am missing something.
edit: Sorry, I just re-read your post. I have encoded my own HD content before, but never from an AVCHD source since I just bought my camera about a month ago (getting the files to play was a whole other matter). My camera is the Sony HDR-SR11.
Problem: Playing HD h.264 file on Xbox 360
By TOMillr in forum Media Center PC / MediaCentersReplies: 1Last Post: 5th Apr 2011, 08:04 -
xbox 360 capture video and audio while playing on pc monitor
By josh123 in forum Newbie / General discussionsReplies: 0Last Post: 5th Jun 2010, 02:51 -
How do I make a H.264 .TS File play normally on xbox 360 extender?
By bubbrubb in forum Video ConversionReplies: 2Last Post: 6th Feb 2010, 13:53 -
mencoder + H.264 + XBox 360 - container and codec frame rate differs
By ali.khalil in forum LinuxReplies: 0Last Post: 24th Sep 2009, 09:31 -
What's the Best Bitrate for Converting DVDs to .264 MP4 files for xbox 360?
By keyed in forum Video ConversionReplies: 1Last Post: 3rd Feb 2008, 02:04
Statistics
Newest guides
Latest tool updates
New media comments
