VideoHelp.com Forum
    hello,i have an old Panasonic recorder model dmr E30 which broke.I have many discs that i have not finalised yet and do not work on other machines.Do you know if some current Panasonic recorder model can work with these discs?
    Yes any newer Panny will play/finalize your disc.
    Depending on what you mean by "broke" if your machine is grinding when writing to DVD then a simple spindle cleaning may be all that is needed.
  3. What type of disks are those? I have that model recorder.
    thanks for your answer.unforunately, a plastic piece of the disc cariage mechanism is broken in half.I will contact Panasonic to see how much it will cost to fix but since the model is old i'm also thinking of biying a new one with HDD but i want to finalise the discs i have.
    thanks for your answer.The discs are all DVD-R .
  6. Let me know if you can't figure it out. My machine still works fine, a bit picky about the drawer opening but otherwise okay.
  1. Panasonic TV remotes....compatibility?
    By Tom81 in forum DVD & Blu-ray Players
    Last Post: 16th Apr 2012, 23:46
  2. Panasonic recorder parts compatibility
    By rmhartman in forum DVD & Blu-ray Recorders
    Last Post: 4th Feb 2012, 17:01
  3. best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
    By overheat in forum Newbie / General discussions
    Last Post: 28th May 2009, 20:57
  4. Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
    By Surfmaster in forum DVD & Blu-ray Recorders
    Last Post: 20th Oct 2008, 20:45
  5. Panasonic dmr es-15
    By jean1938 in forum DVD & Blu-ray Players
    Last Post: 18th Jun 2008, 03:31
