VideoHelp.com Forum
Results 1 to 10 of 10
Thread: Resize HD to SD
  1. Member ron spencer's Avatar
    Can one just simply use spline64resize from 1920x1080 to 720x480 without any cropping? I want to put some HD footage on DVD. Is the resize enough as it is since will be encoded to DVD and flagged 16:9 as aspect
    thanks
    'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
    Yes.
  3. Unless it's 1080i and interlaced.
  4. Member yoda313's Avatar
    Are you sure? I know that standalone dvd recorders record interlaced 480i. Shouldn't it be just as easy to go from 1080i to 480i?
    And also I thought this was referring to resolution not progressive vs interlaced?
    The important thing is to keep it 16:9 assuming that was the original aspect ratio.
    (I could be wrong on the interlaced bit but I said my piece)
    No, if it's interlaced and you simply resize you will end up blurring the two fields together. You want to keep the two fields separate. A crude (but usually adequate) method that a lot of people use:
    SeparateFields()
    LanczosResize(720,240)
    Weave()
    In VirtualDub the equivalent is to Deinterlace (unfold fields side by side), Resize to 1440x240, the Deinterlace (fold side-by-side fields together). Or just use the Interlaced option in the Resize filter.
  6. Member ron spencer's Avatar
    I figured that.....it is a progressive source so no worries...thanks for bit on interlace though....good to know!!!!
  7. Member PuzZLeR's Avatar
    Done the same myself with great results (no distortion, great quality, no headaches) for 16:9 DvD production.
    However I've used Lanczos instead of Spline. Any critique or agreement? Just curious.
    Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
  8. Member ron spencer's Avatar
    lazcos is for upsizing in general
    spline is for downsize
  9. Member edDV's Avatar
    Can someone post short before/after clips for 1080i -> 480i 16x9? Some motion would be useful.
    I want to compare to Cineform, Apple Intermediate Codec and stock Vegas resize.
    http://www.kiva.org/about
    1080i TS file from Hauppauge HD PVR, converted to 480i with AviSynth+HcEnc.
    http://www.sendspace.com/file/9optki
    There's a little A/V sync error in the TS file.
    AvcSource("cut.dga")
    AssumeTFF()
    ConvertToYUY2(interlaced=true)
    SeparateFields()
    Weave()
    ConvertToYV12(interlaced=true)
    Oh, I probably should have done a rec709 to rec601 adjustment too.
  1. Resize MKV
    By joe1974 in forum Mac
    Last Post: 11th Jun 2010, 10:06
  2. Want to resize an avi
    By janlafata in forum Video Conversion
    Last Post: 17th Aug 2009, 23:06
  3. MT2S - Resize
    By HamishT in forum Video Conversion
    Last Post: 19th Jul 2009, 21:15
  4. .sup resize...
    By alcOre in forum Subtitle
    Last Post: 1st Dec 2008, 03:57
  5. can I resize using virtualdubmod
    By thecrock in forum Newbie / General discussions
    Last Post: 22nd Oct 2008, 16:54
