I'm new to Vegas and can't find a way to select multiple clips and drag them all as one. I have this movie I'm making and I need to go back in the time line to add a new clip which requires me to move the rest a bit forward and so far all I can do is to push them all one by one![]()
most editors you get the view correct then hold down ctrl and drag your cursor over the selected clips and drag them
other methods include ripple editing which moves them down once a clip is inserted
probably best to read the directions before going onAuthor, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
Turn on ripple editing. This will preserve the timeline order, even across multiple tracks, when you start shifting things around. Once ripple is on, just move the clip that is in the way along the timeline, and everything after it will shift accordingly. Just remember to turn it off again, as ripple can be both a blessing and a curse.
AWESOME guys thanks, ripple was the answer. Thanks
Sony Vegas, How do you change the clip length of multiple clips? Please hel
By Purplehayes in forum EditingReplies: 9Last Post: 24th Jun 2011, 04:56 -
Sony Vegas Pro - Importing clips from another project
By ClownInBrown in forum EditingReplies: 8Last Post: 18th Apr 2011, 19:43 -
Sony Vegas Pro 8 ... transitions application on multiple video clips ???
By holeepassion in forum Newbie / General discussionsReplies: 3Last Post: 20th Feb 2010, 01:04 -
Combine multiple DVD clips in Adobe Premiere Pro
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2008, 11:55 -
How to strip out unwanted clips in Vegas Pro?
By nzo in forum Newbie / General discussionsReplies: 5Last Post: 2nd Dec 2007, 10:53
Statistics
Newest guides
Latest tool updates
New media comments
