VideoHelp.com Forum
    I'm looking for a hard drive based DVD Recorder, but with some sort of link to PC where I can like "drag and drop" my recordings direct to my PC hard drive for editing. Does anyone know anything like this? Thanks guys, Ani
  2. Mod Neophyte Super Moderator redwudz's Avatar
    I really doubt it would exist. Most consumers seem to buy DVRs for end use, where editing can only be done easily within the DVR. Even HDD DVRs are difficult to find at present. Some users have hacked into HDD DVRs and made the HDD removable or external where it can be moved or hooked to a PC. But DVR manufacturers don't seem to be interested in this.
    But someone out there may know of one.
  3. Always Watching guns1inger's Avatar
    Better off getting a good capture card for your PC.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Ah no worries. Thank you as usual for your help guys
  5. Topfield 5800 (?) is designed to be hook- uppable.. but anyway what I do is simply burn recordings to disc (+rw) and transfer that to computer, any recorder should be able to do that. Have a look at the phillips LX range, out of your price range probably..
    The electronic components of the power part adopted a lot of Rubycons.
    The nearest you can get to this is a 'Dreambox' with a built in hard disk (some do not have them)
    This works like a PVR and records satellite transmissions wherever your dish is pointing to. There is no direct to dvd recording in these.
    The difference of this to a standard PVR is that it is also a PC in it's own right operating under the linux system and you connect this box to your PC by a high-speed lan cable and transfer the recording much faster than real time as you would with a capture device. The recordings are done in .ts (transport stream) format and you can use video editors such as Vegas to do the business.
    The advantage is that you are editing the original digital broadcast whereas with a standard dvd recorder there is some analogue-digital conversion.
    But all of this does come at a price. These units do not come cheap.
  1. Replies: 16
    Last Post: 18th Oct 2011, 18:36
  2. Does such a monitor exist?
    By A Traveller in forum Media Center PC / MediaCenters
    Last Post: 9th Sep 2009, 18:45
  3. Exist a .ts analyzer for h264 ?
    By Robertus in forum DVB / HDTV
    Last Post: 21st Aug 2009, 05:08
  4. HP Product Assistant
    By jyeh74 in forum Computer
    Last Post: 3rd Jul 2009, 18:17
  5. Does this mp3 recorder exist?
    By Theresa in forum Portable Video
    Last Post: 22nd Jan 2009, 13:40
