VideoHelp.com Forum
    Hi, I have a 1080p/8GB .mkv file that seems to be a hog therefore runs slow and goes very out of sync. I have a 4GB RAM quad Code 2.4GH Dell XPS so i don't think its my PC i also can play other 1080p files without any problem.
    Can i fix it by changeing something or maybe recoding it to 720p ?
    It i can fix please let me know THANKS
    File info:
    Format : Matroska
    File size : 7.95 GiB
    Duration : 1h 34mn
    Overall bit rate : 12.1 Mbps
    Encoded date : UTC 2008-11-17 14:38:30
    Writing application : mkvmerge v2.3.0 ('Freak U') built on Sep 8 2008 18:32:16
    Writing library : libebml v0.7.7 + libmatroska v0.8.1
    Video
    Format : AVC
    Format profile : High@L5.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 5 frames
    Muxing mode : Container profile=Unknown@5.0
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 34mn
    Bit rate : 11.0 Mbps
    Nominal bit rate : 11.4 Mbps
    Width : 1 920 pixels
    Height : 1 040 pixels
    Display aspect ratio : 16/9
    Frame rate : 23.976 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.239
    Writing library : x264 core 65 r1028M 83baa7f
    Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=11445 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
    Language : English
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : A_AC3
    Duration : 1h 34mn
    Bit rate mode : Constant
    Bit rate : 640 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Surround: L R, LFE
    Sampling rate : 48.0 KHz
    Language : English
    Have you tried different players like vlc,kmplayer,mplayer or mpchc?
    You could reconvert it using xvid4psp.
    Hi, Yes tried other players, Media Player Classic was a bit faster and more in sync than WMP/MC but still far off. Maybe i will try the re coding thing. THANKS
  1. how to correct out of sync video/audio in mkv file
    By 55trucker in forum Video Conversion
    Last Post: 22nd Mar 2011, 11:08
  2. fixing 'out of sync' audio in video file
    By Nonamer in forum Audio
    Last Post: 19th Feb 2011, 01:03
  3. Fixing audio sync issues when using GOTSent to convert MKV to MP4
    By darrklight1138 in forum Newbie / General discussions
    Last Post: 20th Apr 2009, 06:56
  4. Fixing sound sync issues in a mkv file
    By Psykro in forum Editing
    Last Post: 1st Aug 2008, 05:50
