Hi all, new to the forum so please forgive me if this has been asked before. I did try and search for an answer, but found nothing that I could easily understand![]()
I have a load of Blu-ray films, which I want to convert so my daughter can watch them on her iPod touch.
Can someone please give me a simple noddy guide as to how?
Many thanks,
Thanks for that, will download and give it a try. Already have AnyDVD HD, but could not see a way of getting the ripped Blu-ray file into another file type?Originally Posted by Baldrick
OK, got Ripbot all downloaded, and started to convert the Blu-ray film to MP4. Only problem was it said it was going to take six hours, and that was only on the first pass! Have I done something wrong?
No conversion takes a long time. Is your intel a dual core or a quad core?
Also limit your conversion to the movie only and limit it to the main audio track and that should limit the extra unncessary conversion of extras like trailers and documentaries.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
it seems a bit overkill to convert a 1080 blu-ray film for an iPod touch (resolution 480×320). wouldn't it be easier to go from a SD DVD as a source? soooo much less processing power and time req'd...
Ah, thought I was doing something wrong. I have a quad core 6600.Originally Posted by yoda313
How do I tell which is the movie stream?
Thanks!
@niko - I haven't converted a bluray to know for sure. It is my understanding that it will be the m2ts file that is the largest in size.
Also I don't know how long it takes to convert bluray to mp4 or avi/divx.
One word of advice - limit any background applications while converting. Also probably good to pause any auto antivirus scans during the conversion as well (even a background scan will probably slow it down).Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Newbie question about blu ray ripping and converting
By pete7769 in forum Blu-ray RippingReplies: 8Last Post: 12th Jan 2012, 16:02 -
newbie blu ray question
By cividan in forum DVD & Blu-ray WritersReplies: 10Last Post: 16th Oct 2011, 19:22 -
Newbie question. Have blu ray image, need to convert to quicktime
By apollo1980 in forum Authoring (Blu-ray)Replies: 18Last Post: 29th Dec 2010, 21:25 -
Newbie Blu-Ray Copying and Playing Question
By badadjective in forum Blu-ray RippingReplies: 1Last Post: 23rd Oct 2009, 16:36 -
blu-ray newbie questions
By yogart in forum Newbie / General discussionsReplies: 7Last Post: 12th Nov 2007, 22:08
