Thread: Procoder SVCD
You have to author it using an svcd authoring package. Having never made an svcd, I can't recommend one for you.
normally the files would be .mpv and .mpa or a combined .mpg. check the .m2p and see if it's a vid+aud 480x480 mpeg-2. if it doesn't have an audio channel you'll need to make one with under 384kbps MPEG-1 Audio Layer II out of your source audio and then mux them into a mpg.
you can use vcdeasy to generate the bin/cue files or burn it to cd once you have a compliant mpeg-2--
select the cue file with imgburn in write mode. it is one of the few burning apps that will correctly burn svcd's m2f2 format.
You rock.
Why SVCD? DVD-R media is Cheap. DVD-R/RW drives are under $20 online. FREE DVD players are abundant on www.videohelp.com (please look up Media Player Classic). LightningUK does have the best burner bar none, but I'm trying to work with you on this one.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
I can't speak for the OP specifically, but I can offer some possible answers generally: There are some people who want their media playable on older computers that do not have DVD drives, but which are otherwise capable enough to decode MPEG2 at the required speed. "Get a newer laptop" is not always a practical answer. Or maybe because the cheap DVD-R media they could use is too crappy, and they have a gigantic quantity of good CD-R media they want to use up. Or maybe because the end users are going to be kids who may mistreat the discs, and CDs are more robust than DVDs. Etc.
procoder 2.0 help!
By pagan666 in forum Video ConversionReplies: 0Last Post: 7th Aug 2005, 16:15 -
Procoder vs procoder express
By Dr_Layne in forum Video ConversionReplies: 1Last Post: 13th Jun 2005, 02:27 -
Procoder Xpress vs Procoder 2
By J. Baker in forum Newbie / General discussionsReplies: 3Last Post: 5th Dec 2004, 19:40 -
procoder
By mayday56 in forum Video ConversionReplies: 1Last Post: 9th Jul 2004, 21:39 -
help with procoder
By catdaddio6 in forum Video ConversionReplies: 1Last Post: 8th Jul 2004, 11:17
