I'm kindly asking for a hint or advice about this:
I have 2 laptops connected via wireless (router) to home network. There are other 4 desktop PCs on the network (all with XP).
One laptop is 3 years old HP with preinstalled XP SP2.
Other laptop is 6 months old HP with preinstalled Vista Home Premium SP1.
When I watch video on the laptop with XP, streaming from one of desktop PCs, everything is fine.
But when I watch the same video on the laptop with Vista, the video freezes for a few seconds, every few minutes or so, then continue playing, and so on. It doesn't matter which video player I use or which format of video I watch (AVI, DVD...) - always the same.
The same Vista laptop plays videos without problem from it's own HDD, from DVDRom, will play videos streamed from Internet (Youtube).
The problem is only while streaming over the home network.
Any hint, please.
Thank you.
Results 1 to 12 of 12
More information is needed.
What are you using to play the files?
You may need to increase the buffer in whatever program, you are using.Believing yourself to be secure only takes one cracker to dispel your belief.
A long shot but try connecting the laptop to your network via a wired connection and see if the behavior is different (I've run into some very obscure things that only happen on the wireless connection).
I've said that it does not matter which player I use: VLC, KMP, WMP 11, GOM player, BS player - the behavior is always the same.Originally Posted by Dv8ted2
Increase the buffer? I wouldn't know how (or why). Thanks.
I see no point in connecting it via a wire. I'm not interested in that kind of a connection for a laptop with built-in wireless. Thanks.Originally Posted by JohnnyMalaria
Then there is no point in anyone trying to help you. You won't perform the proper tests to determine where the problem lies.Originally Posted by Jeremiah58
Not at all that I don't want to perform the test.Originally Posted by jagabo
As I said, I don't see a point in it.
I hoped that someone encountered the problem before and found a solution.
I searched for a solution of this problem on Internet, and I saw that many users had similar problem with Vista.
The point is that it will help with troubleshooting. Vista is known for its wireless adapter "quirks" and, as I said, I've seen some odd behavior with Vista + wireless + streaming. I can stream raw DV from my Vista box to/from other computers without any problem as long as I don't use a wireless connection. As soon as I put a wireless connection into the equation, it freezes. It isn't a problem between two XP machines. You, too, have Vista + wireless + streaming. For me, the solution was simple: don't use wireless. Even if you are not interested in a wired solution, knowing whether it is a wireless problem or not will save you further effort or provide direction for further troubleshooting.
The point is to diganose network vs. wireless issues. Describe this network. Is there a server or just a wireless router or peer to peer? Is the problem similar playing audio files? Video files are larger and must buffer up before they can play.Originally Posted by Jeremiah58
This is like saying your car isn't responsive without identifying the car.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
I just ran a large file test (25Mb/s DV) with Vista to Vista wireless, Vista to XP wireless and Vista to Mac wireless. All had delay while the file was buffered before it would play and all paused for rebuffer when wireless traffic increased. I saw more difference player to player than XP to Vista to OSX. On the Mac, VLC was faster than the Quicktime player.
This is just a G wireless network.Recommends: Kiva.org - Loans that change lives.
Yep.Originally Posted by JohnnyMalaria
That sure is the solution.
Just a normal home network:Originally Posted by edDV
ADSL router (Siemens 555) + 4 desktop PC's + 2 laptop PC's
Everything is normal and working fine.
Just that I've noticed that strange behavior on the Vista laptop.
Not that I watch videos on that laptop, so it's not an important issue to me. I watch videos on standalone players and TV.
But I was puzzled - why only on Vista. I presumed that it could be some Vista tweaking in question.
Thank you.
Thank you very much for your test.Originally Posted by edDV
I understand the problem better now.
The streaming which has problems on my side, is from XP to Vista via wireless, though.
Streaming from XP to XP, via wireless, shows no problems during playback of video files.
I haven't tested streaming from Vista to XP.
It may be a local issue. Laptops just run slower due to memory, CPU, disk speed or background tasks. The only way to isolate is to compare to a known good. My Compaq 2core Vista notebook keeps up with the Mac and P4 desktop.Originally Posted by Jeremiah58Recommends: Kiva.org - Loans that change lives.
streaming video stored on one pc to my local network
By cougs_83 in forum Video StreamingReplies: 19Last Post: 6th Sep 2011, 10:03 -
Streaming separate network audio and local video file inputs to a multicast address
By bwehrspann in forum Video StreamingReplies: 0Last Post: 10th Feb 2010, 11:42 -
Using Blueray player ethernet port to play video from home network storage
By gbvideo in forum DVD & Blu-ray PlayersReplies: 10Last Post: 2nd Jan 2010, 12:33 -
Streaming Video with vista 64bit Squashed! HELP!!!!!!!!!!!!
By dking in forum Video StreamingReplies: 1Last Post: 21st Jul 2009, 13:17 -
How do I share printer on home network in Vista?
By LoveMyslf in forum ComputerReplies: 2Last Post: 10th Apr 2008, 12:08
