VideoHelp.com Forum
  1. My USB external HD makes the speaker noise that it is connected, but it doesn't show up under my computer?
    Didn't want to Format It if I didn't have to.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    What brand of USB drive? A commercial model like Free agent or My Book? Or just a hard drive in an external case? A bare hard drive isn't pre-partitioned or formated, but a commercial model in a case usually is, in FAT32 format.
    You might try a different USB socket. What operating system are you using? What are your computer details? Have you tried the drive on a different computer?
    You are unlikely to get many answers unless you supply more information.
  3. Always Watching guns1inger's Avatar
    First place to look in Windows is under Disk Management. Right-click My Computer and select Manage. Disk Management is in the tree to the left. Click on this and see if your drive turns up. If it is there, look to see if the drive letter clashes with another drive. This happens especially on networked machines that have mapped network drives and shares. If it does, right-click on the USB drive and select Change Drive Letter and Paths and give it a letter that isn't being used.
    If the disc is not listed there you might consider removing the USB devices under Device Manager, then rebooting the PC to reinstall them.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  4. Thanks, will give it a try. Will let you know.
  1. External USB DVD burner for $25
    By jimdagys in forum Computer
    Last Post: 2nd Dec 2011, 01:26
  2. Replies: 0
    Last Post: 23rd Aug 2011, 10:04
  3. USB External Burner Problem- help?
    By Super Warrior in forum Computer
    Last Post: 3rd Jun 2009, 22:50
  4. usb external writer
    By bobmeyer in forum Newbie / General discussions
    Last Post: 29th May 2009, 09:55
  5. dvd player +dvix+usb with external 160GB external HD problem...
    By spidermen in forum Newbie / General discussions
    Last Post: 14th Oct 2008, 19:45
