I actually *want* garbed video playback that I can then record and sample in some FX work. Does anyone know of software that won't circumvent copy protection and instead play back a scrambled signal? (I'm planning to capture the playback using screen recording software... its supposed to be garbled anyway so framerate doesn't really matter)
Thanks so much!
Thread: Scrambled DVD Playback
Macro Vision protection is the only one that I know that will play. Most other DVD protections simply through an error code and don't play at all. In the case of MV, it isn't garbled, it simply fades from normal brightness to black and back continously.
Google is your Friend
If you use DVD Decrypter to rip the DVD (Tools -CSS- Cracking Method and check 'None') you get a movie that can be played back, but the screen is pixelated and the audio screwed up.
If you open the encrypted DVD with VirtualDub (using the mpeg plugin), you can save it as AVI and have a video that plays back ditto.
ANYDVDHD BD+ frames may be scrambled?
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 21st Sep 2011, 20:43 -
DVD software's audio is "scrambled"
By takearushfan in forum Newbie / General discussionsReplies: 8Last Post: 11th Sep 2009, 05:38 -
Scrambled DVD
By thepopsicle in forum Software PlayingReplies: 3Last Post: 10th Jun 2009, 13:34 -
Scrambled picture from tv-out
By bizzle_613 in forum Media Center PC / MediaCentersReplies: 2Last Post: 7th Mar 2008, 08:36 -
.avi playback, video is scrambled
By dough in forum Newbie / General discussionsReplies: 5Last Post: 11th Nov 2007, 13:19
Statistics
Newest guides
Latest tool updates
New media comments
