Adobe Premiere Elements 7.0 is not able to import video from the built in memory, only from the SD Card. I can read the built in memory with explorer, and Premiere can read it if I choose "Get media from PC files and folders". But if I do that, the files are not moved to the harddisk. Do I have to move the files manually and is there a problem with that apart from having to create folders myself?
I have not installed anything from the Digital Solutions Disk. I'm using vista and the installer only shows ZoomBrowser and image gateway registration guide. I don't need any of those and I don't think they will help in accessing the camara flash memory.
When video is moved from the SD card to harddisk, it looks like only the .MTS files are moved. Is that all I need? There is a whole lot of files on the card. Do they not contain any useful information? Is the time and date for instance incorporated into the MTS file?
Results 1 to 1 of 1
Lost with Premiere Elements 10 & Canon Vixia M41
By skyfranks in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jan 2012, 22:16 -
Canon HF10 vs HF20
By jazu in forum Camcorders (DV/HDV/AVCHD)Replies: 15Last Post: 2nd Jun 2010, 12:29 -
Canon HF10 - 50i or 25p ?
By theaterguy in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 17th Nov 2008, 01:57 -
Canon HF10 NTSC or PAL
By Jone.T in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 29th May 2008, 11:57 -
Canon HF10 und Sony Vegas
By miepel in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 19th Apr 2008, 15:27
