Hi
Thanks for a great program. Used it since version alpha.
Not used it for some months now and upgraded to latest version yesterday.
Adds mkv or Mp4 files, tried both. Creates menu with default background.
Clicks create with menu and no burning and the log stops at "creating TiltleSet#1" and then I get the following error.
(I have checked my memory and it is OK).
Version: SVCD2DVD 2.5
Build: 2.5.5000.0
Type: System.AccessViolationException
Source: SVCD2DVD
Message: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
InnerException:
StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.AuthorDVD(xc76 139390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82, Boolean x6b20cb17e8070d92, Boolean x3c21da9f928aac10)
at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
Afterwards SVCD2DVD closes.
Thread: System.AccessViolationException
Can you send your log? (Help->Open Logs folder)
Also 5010 is the latest build, can you try that?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Hello,
I get the same error message while trying to make a dvd from an mkv.
However the demo version v2.5.3600 works fine. No error and a perfect dvd at the end.
What I discovered was that the demo version creates a temporary mpg file with size increasing while processing the mkv file. The full version build 2.5020 creates an equal mpg file but it's size is always 0 bytes.
So I think the problem is caused by ffmpeg.exe.
I tested this on Vista and XP both fully patched with the same error.
Would it be possible to get the full v2.5.3600 version? I really would appreciate this since this version works fine for me.
Build: 2.5.5020.0
Source: SVCD2DVD
InnerException:
Sure - drop me an email.Would it be possible to get the full v2.5.3600 version? I really would appreciate this since this version works fine for me.
However - can you also email me your log file for this run so i can get to the bottom of it please?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks for the 3600 versionHowever - can you also email me your log file for this run so i can get to the bottom of it please?
Just sent the logfiles to you.
New system
By didikai in forum Newbie / General discussionsReplies: 14Last Post: 21st Jun 2011, 07:36 -
By dw1 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 3rd May 2010, 12:59 -
Certain Files Crash the App With a AccessViolationException (RESOLVED)
By sengsational in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 11th Jul 2009, 12:33 -
System
By Seasonal in forum ComputerReplies: 3Last Post: 26th Jun 2007, 09:54
