VideoHelp.com Forum
    i have a samsung standalone. i tried to update with usb drive, and im not sure if it didnt finish, but after that none of my burnt discs would work, and my actual blurays didnt load. so i took it back and exchanged it. i got a new one, and everything plays fine, but it has a network port on the back and i know there is bluray 2.0 update out there. woudl that prevent burnt bd5 and bd9 from playing?
  2. Member Krispy Kritter's Avatar
    Which model are you using? The manual should outline the procedures. It sounds like your first update failed.
    Google is your Friend
    Don't do it ..........................
    I did it via cd and it did the same to mine , no avchd would play after..
    Then i redid using usb and killed the drive
    BOBO.........
    If at first you don't succeed........
    Ask someone that knows what there talking about !!!!!
  1. Replies: 8
    Last Post: 5th Mar 2011, 18:00
  2. Samsung BluRay BD-C5500
    By ce6pcm in forum DVD & Blu-ray Players
    Last Post: 8th Jan 2011, 18:23
  3. problem with my samsung bluray bd 1500
    By jpapa in forum DVD & Blu-ray Players
    Last Post: 6th Nov 2010, 16:28
  4. Replies: 4
    Last Post: 25th Sep 2010, 15:35
  5. Using a samsung home theater as bluray audio playback?
    By mordeckai in forum Newbie / General discussions
    Last Post: 4th Jan 2010, 07:55
