VideoHelp.com Forum
Results 1 to 9 of 9
    I really appreciate if anyone teels me how to play a .TPO extension file
    It supposed to be compatible with mpg format
    what made it and/or where did you get it? not enough info to answer your q.
    It is a format exported out of the new set top boxes or home theaters more specifically Homecast.
    try mediainfo and gspot and see what info they come up with. you might try renaming th efiles to end with .mpg and see if that helps.
    Thank you
    I now have managed to open and view the files with Womble's Mpeg2vcr a little grainy but I'll see what can be done as end result.
    According to this link http://www.abadss.com/forum/804-cool...onversion.html the file extension is t-p-zero and can be converted with MPEG StreamClip. google is your friend. Also mentioned in this post http://forum.videohelp.com/topic331577.html referring to TP0 files
    Thank you for the additional utility but seems to be wanting to install Quicktime Alternative rather than Quicktime itslef.
    Yes MPEG StreamClip can covert *.TPO to *.mpg on the fly, good quality and then edit in videoredo no problems at all. I still do not kow why other options to convert are not available in Windows even though I have codecs and filters installed.
    Finally and for other people benefit I have found that
    DVR Studio Pro can make a DVD on the fly directly from these type of files although an expensive program.
    http://www.haenlein-software.com/HS/...e55ca3e0e49106
  1. how to play "eps" extension files ??
    By vikas.babu in forum Software Playing
    Last Post: 2nd Jun 2010, 19:08
  2. .PS to any video extension
    By wazza88 in forum Video Conversion
    Last Post: 2nd May 2010, 20:56
  3. Can anyone please help me to play the movie with mt2s extension
    By Grendel007 in forum Software Playing
    Last Post: 23rd Jan 2010, 14:58
  4. how to play files with extension mod and moi
    By greendesert in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 14th May 2007, 06:07
