I have a 3 month old US model Phillips DVP5990 player. About every 30 minutes the video cuts out, black screen, for about 2 seconds then comes back. The video is still in time with the audio when it comes back. The audio doesn't miss a beat. This is while playing any of my .avi videos. Factory firmware.
Any idea on what's going on and any way to fix it?
Thread: Phillips 5990 video cuts out
Is this on a disc or usb and how is it connected to the tv?
I've not tried from USB. It's only happening with discs as far as I know. Connected with HDMI from the DVD to reciever to TV. Hmm..., could possibly be the switching in the reciever too, huh.
I'm going to try another HDMI input on the reciever to try to rule it out.
I flashed the firmware on the 5990 yesterday to 1.2.1. No change in video cutting out randomly.
Im seeing a similar issue with the divx played either from dvd or external hard drive. I had a 34xx series before, and all of those files worked perfectly. With the 5990, the divx play for a bit then the whole unit freezes. Not on all, just some
I think I might have discovered what's going on. Seems the 5990 is very sensitive to static electricity or the player being powered from a non grounded outlet. Maybe the rotating dvd disc is creating a static build up inside the player somewhere and discharging. When it does, the picture drops out. If when I walk up to the player and touch it and static from me discharges to the player, the picture drops out.
All of the outlets in my home are 2 prong only, none are 3 prong grounded type. I had the player power cord plugged in to one of my recievers switched outlets. I removed it and plugged it into the power strip I have some of my other components on, tho it's still only plugged into a 2 prong outlet. But since doing so, I haven't had the video drop out. As before, I couldn't watch a disc without the video dropping out every 10 seconds, it was getting that bad.
I need to talk to an electrician to see if there's any way of grounding the electrical in my home, without tearing out the walls to replace the wiring.
encode cuts video ?
By stefniamoo in forum ffmpegX general discussionReplies: 1Last Post: 25th Jul 2011, 13:25 -
Mp4 video plays audio then cuts out
By nick101181 in forum Software PlayingReplies: 1Last Post: 26th Mar 2011, 06:25 -
Phillips 5990 with large External Drive formated with Swiss Knife
By greasyspoon in forum DVD & Blu-ray PlayersReplies: 5Last Post: 18th Apr 2009, 17:26 -
Phillips 5990 - How to revert back to original firmware
By user111 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Feb 2009, 19:31 -
Phillips DVP-5990 - HDMI problem?
By Ai Haibara in forum DVD & Blu-ray PlayersReplies: 5Last Post: 3rd Jan 2009, 02:18
