VideoHelp.com Forum
    with a 300 watt psu?. It is a 3+ year old pc. Either the 256mb or 512mb version?
  2. Mod Neophyte Super Moderator redwudz's Avatar
    The 300W PS may be a problem. E-Machine power supplies have a bad reptutation for failure. I would replace the PS with a name brand PS, 400W should be plenty. Hopefully, the PS is standard size.
    That card doesn't appear to have a external power supply hookup, so I'm assuming it doesn't draw as much power as some newer cards with that hookup.
    If you use the present PS, there is a higher risk of failure and that could take the MB, CPU and drives with it if it dies. Not worth that risk, IMO.
  1. eMachines DV capture possible?
    By GavSalkeld in forum Capturing
    Last Post: 27th Nov 2011, 12:50
  2. Will my pc run W7 32bit?
    By neworldman in forum Computer
    Last Post: 20th Oct 2010, 14:42
  3. second HD on old emachines
    By mac71671 in forum Computer
    Last Post: 18th Sep 2009, 13:51
  4. Emachines EL1300G-01w DVD Burner
    By Max Renn, Channel 83 in forum DVD & Blu-ray Writers
    Last Post: 29th Jul 2009, 10:38
  5. Monitor settings (on Emachines 17" CRT Screen)??
    By willhenderson in forum Computer
    Last Post: 14th Dec 2007, 09:40
