Hi,
I'm using MP4 converter on my Mac to rip DVDs for my PS3. I was wondering what the best setting is for ripping. I've let i be default settings because I'm not really sure what to change. Is it the bitrate? The only thing I change is the file size, it allows you to break it up for your iPod or CDs etc. I always have it on "infinite" so it's one file. And it's set to "PS3 Video 480 (Excellent)." The issue with this is the file takes forever to rip. It usually takes about eight hours and skipps every few seconds for the whole video. The file ends up being a gig an hour. Any help would be appreciated.
Try something else like handbrake. And by changing the file size you also change the video and audio bitrate, higher file size = higher bitrate = better quality.
I believe they've pulled the built in support to rip DVD's from Handbrake, but you can install VLC (version 0.9.x) and get the same functionality back into Handbrake from the libdvdcss library it installs. If that doesn't suit you, you can just use Mac The Ripper. It works pretty well for basic DVD ripping, giving you a unencrypted VIDEO_TS and AUDIO_TS folders.
I agree, Handbrake is an excellent and free piece of software
For DVD's, try setting your bitrate between 500-1000 kbps, depending on how clean (new) your source is. Newer digitally shot movies have no analogue noise, and will encode with very little bitrate at 720x480. The same is true for anime.
Impossible to see the future is. The Dark Side clouds everything...
which 'create DVD from MP4" app for Mac that takes any kind of MP4?
By callagga in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2012, 19:46 -
MKV Converter for Mac to play on PS3
By adamski911 in forum MacReplies: 3Last Post: 16th Feb 2010, 18:02 -
The Best Xbox 360 and PS3 mkv video converting to mp4 App.
By spyder7777 in forum Newbie / General discussionsReplies: 0Last Post: 11th Apr 2009, 04:55 -
converting videos to MP4/PS3 with SUPER - gray flashing frames
By xycer in forum Video ConversionReplies: 1Last Post: 8th May 2007, 18:47
Statistics
Newest guides
Latest tool updates
New media comments
