hi i am after a simple way to replace the audio on my dvd which has crappy music on it i want to put my own commentary on it but all the ways suggested on this site are so complex and after doing most of them none really worked at all surely their must be a simple way to do it something must be available any help would be most appreciated thanks
phillip cole
Results 1 to 11 of 11
Thread: replacing audio on a dvd
Simplest way - demux the video and create a new DVD with your new audio. Any method to actually replace the audio in an existing DVD while keeping everything else intact will be complex and fiddly.
Yep.
1. Demux (PGCDemux)
2. Replace the audio while remuxing (Muxman)
3. If necessary or wanted, replace the new DVD back into the original, thus keeping the menus and any extras (VobBlanker)
I got a PM from phillbrett68 asking for details.
Go to Method 2 of Baldrick's subtitle replacement guide:
http://forum.videohelp.com/topic338721.html
It's about replacing subtitles, but the principle's the same. In the first PGCDemux pic, tick Mode->By PGC rather than by VOB ID. After demuxing you'll have all the original pieces. Dump the original audio for your new one. In the Muxman step, make sure to use the Celltimes.txt (the chapters) by loading it in File->Import Chapter. Load the video, your new audio, the subs if any, give it a destination and Start. When done you'll have a DVD of your movie only, with the new audio. No menus or anything else yet. Test it out in a software player like PowerDVD to make sure everything checks out. Then go on to the VobBlanker step. Test the DVD again when done, before burning to disc using ImgBurn.
hi i have since learned the music on this dvd which we dont want was added with adobe premiere pro is their a way to add the new audio track in adobe premiere pro and make the first track quiet at all can anyone tell me thanks i did try the suggested above but with no luck whatsoever the music didnt get removed so i have no idea how to remove it at all
bye
from phillip cole
You can't remove the music, as it is mixed into the audio track. Premiere Pro may have been used in the editing and audio mixing stage, but it won't help you here.
any suggestions then as all the previous suggestions have failed to work at all
i have tried several things myself but none of which have worked at all
bye
phillip cole
If you have an audio track with vocals and music, and you don't want the music, then you will have to get the original audio without the music. Otherwise there is little else you can do.
Maybe tell us what isn't working and at what stage of the replace process you're in. Error messages, logs, and the like, would help greatly. We're good, but not clairvoyant.
If by "it doesn't work" you mean "I can't remove only the music," that's the expected result. As the others said, you only have a single audio track. So, your choices are limited to: 1) live with it; 2) Replace the ENTIRE audio track with an entirely new one; 3) Watch it in silence. Really, those are it.
You want a fourth option, "undo the addition of the crappy music." But that's not an option. You cannot unscramble an egg, and your audio is a scrambled egg.
If you have been trying option 2, and THAT isn't working, then we can help. Just do as manono says, and tell us exactly what you've been trying, and where things fail. We're neither clairvoyant nor telepathic. Don't make us guess.
hi i have given up trying to replace the audio and will let someone who knows what they are doing to do it for me thanks anyway
bye
from phillip cole
Replacing a DVD audio track
By mltwitz in forum DVD RippingReplies: 2Last Post: 13th Jun 2010, 19:58 -
help replacing audio on DVD
By fullbohr in forum AudioReplies: 3Last Post: 12th Nov 2009, 20:34 -
Replacing DVD audio (question)
By Colmino in forum Authoring (DVD)Replies: 20Last Post: 7th Apr 2009, 03:11 -
By phillbrett68 in forum Authoring (DVD)Replies: 2Last Post: 7th Dec 2008, 01:00 -
Replacing DVD Audio stream.
By GangstaRap in forum Authoring (DVD)Replies: 2Last Post: 27th Feb 2008, 06:21
