Hi guys.
I'm using a ASUS U3100 USB2 HDTV tuner, and for the life of me, I can't find a program that will convert the original file to a smaller size.
Results 1 to 18 of 18
What type of file does it produce ?
All Australian DTV broadcasts are Mpeg-2 with either AC2 or MP2 audio. Generally DTV capture devices give you two options for output. They will either give you the entire Transport Stream (.TS) or just the Programme Stream (.mpg). Some cards offer a third option, which is to transcode to another format on the fly. This is not something I recommend.
I capture programs streams regularly and have no problems with either of those tools (I use both).
Post a g-spot of the files in question so we can see what you actually have.Read my blog here.
General
Complete name : C:\Documents and Settings\DAVO2\My Documents\My Videos\TEN HD_11_23_2008_21_11_01.mpg
Format : MPEG-TS
File size : 322 MiB
Video
Menu ID : 1601 (0x641)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, Matrix : Default
Bit rate mode : Constant
Bit rate : 90.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate : 25.000 fps
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 1.736
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format profile : Dolby Digital
Bit rate : 448 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Video delay : -810ms
Language : English
Language_More : Clean effects
Text
Format : Teletext
Language : English
I couldn't open it with avidemux. -
What is your final format goal? (.eg. do you want it playable only on PC, or standalone DivX DVD player etc....)
Are you able to play it back in a directshow player like MPC? If so, then you should be able to convert it with xvid4psp to many formats
Can you open it up and index it with DGIndex (DGMPEGdec) ? If it indexes properly, you should be able to use avisynth and any encoding application that accepts .avs input to encode it to something else
If your .ts has errors or discontinunities/drop outs , you can sometimes fix it by running it through projectx or pvastrumento (for MPEG2 .ts) - this might be why avidemux & videoredo refuse to open it (if the error is at the beginning of the stream) -
I would like to be able to at least convert the original HDTV ts file down to a 1280x720-5000kbps video for playback on the PC.......this still looks good and saves quite a bit of space.
I'll investigate the other options you gave when I can, but I just thought I'd add that AGK accepts the file but doesn't recognize the audio, in fact, it allows me to use it's WMP9 preview player, but the sound bar is dead and has lost the option to mute or increase/decrease sound. -
AC3 filter didn't work
http://rapidshare.com/files/171573679/Nine_High_Definition_12_09_2008_07_46_56.mpg
I wonder if anyone would dl this 45mb 1080i clip and see if they can figure out why it's being so recalcitrant...? -
It works fine, you need haali media splitter (or a proper splitter) to play it in MPC or directshow players.
AC3filter works to decode it properly on playback
All converting progams seem to work with it here on my test system. (incl. avidemux)
So make sure you have haali media splitter, ac3filter, and an mpeg2 decoder (you can use ffdshow, just enable MPEG2 in the configuration) -
it works, but is more like a transport stream than mpg. i used HDTVtoMPEG2 on the file mpg-> mpg and then everything could play/use it.
Originally Posted by poisondeathray
I'll install haali and see what happens.
With my old 1080i tp files, video-redo would open almost instantly even if the file was 20gig. -
I was able to open the 330mb in video-redo, convert it to a TS file and AGK now recognizes the AC3....and using my new E8400, I converted the the 330mb to a 99mb in 9mins.
Thanks to everyone who tried to help me.
Just in case people are reading this and now think the ASUS U3100 is da bomb, unfortunately it isn't.......ie, my old PCI capture card used to introduce skips/glitches, so I boosted my antenna and it made a 2000% difference to signal quality, however, even with my high gain antenna, the Asus skips way too much, granted you can use AGK to minimize the damage, but I think PCI-PCIe is the way to go. -
Well after fixing the problems I had, it dawned on me that the Asus is still a PITA as it skips and I have to run it thru video-redo if I want to allow AGK to accept the files, so I bought a Kasier Baas USB and the tuner is a thousand times better, plus AGK recognizes the files without having to convert them to a ts.
Question about Video Redo
By snafubaby in forum EditingReplies: 6Last Post: 26th Feb 2012, 04:01 -
Video Redo problems
By Phaneendra Rao in forum Authoring (DVD)Replies: 6Last Post: 25th Feb 2012, 02:32 -
BD player Sony BDP-BX57 not recognizing .srt files from external USB memory
By arjuna1980 in forum SubtitleReplies: 0Last Post: 7th Jun 2011, 13:07 -
A question related to sub files and resized avi with AGK
By loninappleton in forum Newbie / General discussionsReplies: 7Last Post: 19th Jul 2009, 22:35 -
GUI for DVD and Video Redo both crash Win2k
By Skarr11 in forum Authoring (DVD)Replies: 1Last Post: 20th Jul 2007, 17:02
