I have tried to encode my movie.mt2s file with RipBot using BaldRick's guide , but I get over 36 hours estimated encoding time after 1 hour encoding!!!
I used the same setting as given in the guide. I have a Intel core2duo E4600@2.4GHZ with 3GB ram and vista home premium 32bit. No other software are running.
Why does it take so long ?
Thank you for your help
Thread: Ripbot very very slow
Check your Task Manager. It should be using close to 100% CPU during encoding. I use a quad core Q9300@3Ghz. It takes about 6 hours for a BD to MKV two pass conversion to a 4.37GB DVD-5. More cores speed up those type conversions.
My guess it should take about 14 or 15 hours. Maybe there's a problem there somewhere.
What settings did you use in RipBot? I normally use 2 pass to MKV.
ripbot 1.17
By zero7404 in forum Blu-ray RippingReplies: 17Last Post: 27th Apr 2012, 11:25 -
Ripbot Issue
By Yeomans in forum Newbie / General discussionsReplies: 2Last Post: 12th Sep 2010, 07:28 -
RipBot v1.15.0?
By ajgoyt in forum Newbie / General discussionsReplies: 4Last Post: 3rd Mar 2010, 06:14 -
ripbot
By jonno232 in forum Video ConversionReplies: 1Last Post: 18th Mar 2008, 22:50
Statistics
Newest guides
Latest tool updates
New media comments
