VideoHelp.com Forum
Closed Thread
    I have an 8gb avchd iso and i cant load it into tsmuxer. but image burn will let me burn it. can i just burn the image and play on my blu-ray. thanks
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator Baldrick
    If you made the iso properly (authored to blu-ray spec); and the content is compliant (it has to fall within compatible specifications; e.g. if you have too many b-frames it won't work, too many reference frames it won't work, etc...)
    You can mount the iso with emulator software, eg. daemon tools, and look inside to see if it has the blu-ray structure (bdmv, stream etc....) (check here if it looks similar http://www.videohelp.com/hd )
    I already mentioned this in one of your other threads, some blu-ray players are picky, either about the media, stream compatiblity, or in general.
    The only way to figure out is to try it
    This is my final warning. PLEASE STOP MAKE NEW TOPICS. Use http://forum.videohelp.com/topic360620.html .
  1. AVCHD to BluRay question (again)
    By pijetro in forum Authoring (Blu-ray)
    Last Post: 8th Jan 2012, 14:04
  2. AVCHD conversion question
    By ranchhand in forum Video Conversion
    Last Post: 24th Feb 2011, 11:53
  3. AVCHD Conversion question
    By graydon creed in forum Video Conversion
    Last Post: 24th Oct 2009, 06:26
  4. avchd question
    By eric11111 in forum Authoring (Blu-ray)
    Last Post: 9th May 2009, 23:04
