Previous version of SVCD2DVD worked fine on my Vista machine. I noticed the newer version so I uninstalled the old & installed the new. Prog. installed fine-I went into the folder and chose to run as admin and I got the message: SVCD2DVD has stopped working-Please wait while windows searches for a solution. Any advise?
My system: 4gb ram/amd2 6000/ms vista 32/. Thanks
Results 1 to 14 of 14
Thread: All was fine up until now.
I downloaded new version today also (dec 8) still have same problem
Do you want to email me and I'll send you build 3600 to try again?
well i tried build 3600 and still the same problem. i even uninstalled .netframe. and reinstalled. not sure what else to do. I keep getting "svcd2dvd stopped working-please wait while windows finds a solution" Am I the only one with this problem? (same problem with the newest build that came out 12/17
I realize the info I've provided may not be that helpful~If there is something I've overlooked please let me know so I can help further.
thanks
Can you send me an email and let’s try a few diagnostics?
E-maile on they way. Thank you!
ChrissyBoy does it again
Problem solved! Apparently my Tahoma and Arial fonts had become corrupt. Thanks again Chris!
Paul
I am having the same problems, I have downloaded the latest version ov SVCD2DVD for a clean install on both a Vista 32 bit and Vista 64 bit systems. On both systems the demo version works fine but the registered version crashes. Both passes complete almost at once, windows gives a ffmepg.exe has stopped working and the progress bar continues to scroll actross the bottom of the application. The output contains 0 bytes. any help would be appreciated.
Thanks,
David
Thanks,
David
A little more information, I found my backup version and tried it. The old 2.5 version of works fine so the problem seems to be with the latest version
have you got a log file of such a run please?Originally Posted by cobbdSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Let me reinstall the new version, I had several files to process so once I got it working with the old version I just used it. I would like to understand the problem though. Please give me a little time to generate the logs.
Thanks,
David
reloaded recent registered version and just gets registration but fails to star any ideas?.
got it sorted by installing away fromc:/ prgramme files, as read elsewhere in forum
DVD playback fine on computers, but not so fine on home players...
By stonesfan in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 17:03 -
ffmpeg fine concatenation does not work
By peterdolson in forum Newbie / General discussionsReplies: 1Last Post: 31st Jul 2009, 14:56 -
M2TS fine, MKV not so fine.
By sixleaf in forum Blu-ray RippingReplies: 6Last Post: 26th May 2009, 02:35 -
Sticky Labels - once dead, now fine
By NoBuddy in forum Authoring (DVD)Replies: 2Last Post: 22nd Dec 2008, 14:03
