hi i have a couple of files which are x264. i used svcd2dvd to make vob files which work great on my dvd player. my question is how much video quality do i lose when converting to vob files. thanks
Closed Thread
Thread: x264 1080p blu-ray files
A lot of quality is lost
1920x1080 => 720x480 has 6x fewer pixels
Transcoding to any lossy format makes the loss even worse
You are going from h264 => MPEG2 which has worse compression
And you are probably lowering the video bitrate to make it legal for DVD (<9Mbps)
whats the best way to do this with the x264 without losing quality. also what about avchd files i can just burn the image to a dual layer correct. thanks
It is impossible to not lose quality.
There is no best way. You can try FAVC to convert, it uses HCenc which is a high quality free MPEG2 encoder.
For AVCHD files, do you mean full HD on a blu-ray player? or DVD player?
IF blu-ray then use tsmuxer, and burn with udf 2.50
You can't play AVCHD on DVD players.
im a little new. i bought a sony s350 player today and i have a couple of avchd files. so i burn to a dual layer disc than play on the blu-ray correct. now i have to chanhe the file. please explain. thank you
I already answered in your other post: (maybe a mod can merge the threads)
http://forum.videohelp.com/topic360620.html
cheers
No. I can't merge threads using this forum.
eric11111: PLEASE USE ONE TOPIC AND DO NO CREATE A NEW TOPIC.
I want to convert my 1080p video files to a blu-ray disc while keeping.....
By mad555 in forum Authoring (Blu-ray)Replies: 7Last Post: 30th Jan 2012, 08:51 -
Need help to convert Blu-ray MKV 1080 x264 Video files
By AndreL in forum Blu-ray RippingReplies: 4Last Post: 18th Jul 2011, 16:04 -
Blu Ray 720p vs 1080p
By zork152 in forum Newbie / General discussionsReplies: 6Last Post: 11th Jan 2010, 11:32 -
Looking for a cheap laptop to play 1080p x264 and blu-ray files
By bigshotceo in forum ComputerReplies: 2Last Post: 23rd Jun 2009, 10:33 -
DV AVI to 1080p? Thence Blu Ray?
By Maxwellbest in forum Video ConversionReplies: 4Last Post: 16th Jan 2009, 15:45
