Do I need to re encode if I want to join avi one to another.
I have 10 files of 70 mb each in avi format. XVID I think. When I use direct stream copy i get a single file of over 3 gig. Can any wise member tell me abut this?
peace
Thread: virtualdub append question
“He who makes a beast of himself gets rid of the pain of being a man.”
If ten 70 MB files turn out over 3 GB you must not have used Direct Stream Copy. Be sure both audio and video are in Direct Stream Copy mode.
Note that the append operation will automatically append sequentially numbered files. So if your files are named like:
file01.avi
file02.avi
file03.avi
file09.avi
file10.avi
You only need File -> Open Video File file1.avi, then File -> Append AVI Segment file02.avi. file03avi through file10.avi will automatically be appended. You can disable this behavior at the bottom of the file dialog (if you wanted to append them out of order, for example).
Nice one jagaboo,
I was appending all of the files and this must have been selecting all avi's each time I appended. No wonder such a large file size.
Peace“He who makes a beast of himself gets rid of the pain of being a man.”
[Resolved] Making 2 AVIs the same so that VirtualDub can append?
By Diana (Cda) in forum DVD RippingReplies: 32Last Post: 9th Dec 2010, 14:01 -
Cannot append, files use different compression
By PirateBill in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2009, 21:04 -
Cannot append some AVI files in VirtualDub.
By StehpenRH in forum EditingReplies: 3Last Post: 8th Oct 2008, 04:51 -
Problem with Append AVI in VirtualDub - Audio of Sync - How Fix?
By Chakra in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 18:00 -
Deshaker, where to append 30 frames?
By RickA in forum RestorationReplies: 5Last Post: 28th Jan 2008, 14:13
Statistics
Newest guides
Latest tool updates
New media comments
