When I tried to encode some mpeg2 or dvd videos to other format ps3, psp etc, it says there is no YV12 encoder installed, and I have tried to install the decoder but all to no avail. Please help.
Cheers
Results 1 to 11 of 11
install divx codec (or real video yv12 decoder)
make sure to disable your antivirus when installing it (could prevent registry changes)
BHHHDConvertToX, AutoMen, AutoMKV Developer
Thanks a lot for that, works fine now, however i still have another problem with encoding MKV files, I always get an error the message I get is "wMultOf must be zero"
thanks in advance.
how are you configuring it ?
have you installed all needed application ? (like a decoder as ffdshow)
Hi Buzz.
Glad you got it working. As buzzqw pointed out, to display/render YV12 all you need is the DivX codec (or special decoder). And it would also work with the Xvid codec as well. All are very fast with colorspace conversions. I posted also to warn never to install any of those codec packs that may mislead you into better "universal playback" (in case you ever reformat your hard drive and start over or in case someone else is reading this).When I tried to encode some mpeg2 or dvd videos to other format ps3, psp etc, it says there is no YV12 encoder installed, and I have tried to install the decoder but all to no avail.Can you give us a bit more info? Are trying to encode from MKV or to MKV? Also keep in mind, MKV is only a container - it can host many different video/audio formats inside. What exactly are you trying to do? Do you get this for all conversions or just those of one type?Thanks a lot for that, works fine now, however i still have another problem with encoding MKV files, I always get an error the message I get is "wMultOf must be zero"
Longshot: could it be the resolution you want to encode to is illegal for that device/format?Been away for a while and busy with work the last few months so I had no time for forums. My apologies for any emails I couldn't get to in time - missed you all! :-)
Anytime I've had trouble with XVID4PSP I just re-install ffdshow (using whatever version is current at the time) and that seems to fix it up.
Of course I'm always installing other (usually video releated) programs that I think must affect ffdshow somehow. I guess re-installing it fixes it.
1.) Re-install ffdshow
2.) Re-install XVID4PSP
3.) Reboot
4.) Try again
5.) Should work now (fingers crossed)
thanks for all your reply, actually what am trying to do is, I have some vob and mp4 files which I muxed from MKvs, but now I want to convert them all to psp format Anamorphic 480x272, but when I open the file using Xvid4psp, after caching the file it comes up with the error saying, "wMultOf must be zero". I have tried to load original MKV files but with the same result.
Did you do what I suggested above?
Do you have Haali Media Splitter installed?
Well you don't have something set up correctly. Maybe too many other codecs. A lot of time a multitude of codecs can screw things up.
Often the only way to fix that is to re-install just want you need but if that doesn't work ... it often means re-installing Windows so as to get a fresh clean start.
Converting YV12 to anything else causes inexplicable blockiness
By Asterra in forum CapturingReplies: 13Last Post: 19th Apr 2011, 06:02 -
Confused over colorspace (YV12) and DV AVI
By sasuweh in forum Video ConversionReplies: 4Last Post: 30th Sep 2010, 05:34 -
error yv12 fliter??
By f1st in forum Video StreamingReplies: 0Last Post: 21st Mar 2009, 11:04 -
DVD to DVD: YV12 to RGB to YV12, color problem ???
By cd090580 in forum RestorationReplies: 9Last Post: 24th Oct 2008, 10:16 -
Combining PowerDVD 7's Audio Decoder and Microsot's MPEG-2 Video Decoder
By Dark Alpha in forum Software PlayingReplies: 4Last Post: 11th Sep 2008, 18:44
