The video clips were captured from a DV by the Windows Movie Maker. But, there was no sound after the video clips captured. Do you know what problems look like? I would like to capture the video and sound from the DV.
Please post dv "capturing" in our dv forum. Moving you.
Have you tried record the dv using something else like windv? Same problem?
Hello coody;
Only a guess, but do you have the audio muted on either your source or in Windows Movie Maker ?
This is taken from the help section of WMM.
If you move the slider all the way to the Audio/Music track, the audio from the video clip may be played for two seconds or so when the project is previewed in Windows Movie Maker. However, in your final saved movie, the audio will play back as intended where the audio from the video clip is muted.
As I previously stated, only a guess.THREADKILLER !
References on File.
No, I did not check the option of Mute Speaker. I use the DV 4 pins cable to connect my PC instead of the USB. Is it the correct connection or I must use the USB to connect the PC? By the way, Is the DV 4 pins cable same as the i.LINK cable. My DV is Sony.Originally Posted by wtsinnc
As far as I know, it makes no difference as to whether you use IEEE (4 pin) or USB to connect to your computer except that your particular model camera may have different audio out settings for IEEE and USB.
Your manual will explain how to check that.
Windows movie Maker should recognize the output from your camera regardless of which method (IEEE or USB) you choose for transfer.
Be sure to check the audio settings in WMM (Tools/Audio Levels) and set as necessary.THREADKILLER !
References on File.
Windows Live Movie Maker – How to mute the audio from the video clips?
By coody in forum EditingReplies: 1Last Post: 14th Aug 2011, 03:03 -
Windows Live Movie Maker - Sound Not Sync'd
By iHackMario in forum EditingReplies: 2Last Post: 27th Aug 2010, 17:44 -
Windows Movie Maker-Sound but no video WMV files
By mwilliams1220 in forum EditingReplies: 2Last Post: 29th Oct 2009, 14:08 -
Windows Movie Maker. Blank video when splitting, trimming video clips
By rlarden in forum EditingReplies: 2Last Post: 3rd Jul 2009, 06:23 -
using quick time video clips in windows movie maker
By benmar in forum Newbie / General discussionsReplies: 2Last Post: 7th Aug 2008, 10:43
