Is this possible? I have 13 ntsc vhs tapes, roomate has a pal camcorder and I want to pass them through it into my mac for final cut pro. Then burn to dvd for playback on ntsc.
Why haven't you tried it?Originally Posted by tozier9
We don't know any details about this camcorder.
It isn't likely.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
In all likelihood the PAL camcorder will not sync to the NTSC signal.
I live in Big Sky and we don't have any electronics stores, I would have to order a firewire to try it.
The camcorder is a DCR-PC55E Pal.
My room mate said he has hooked it up to a few tv's in the states and it played fine.
It is highly unlikely that a consumer level Sony would be able to encode PAL and NTSC to DV via the analog inputs. Indeed, most camcorders sold in the EU have the DV IN feature disabled and cannot encode anything.Originally Posted by tozier9
Some PAL Sony's can play NTSC tapes and vice versa though in a rather bastardized way (the TV needs to support pseudo PAL/NTSC. Many do not send the DV via FireWire. Conversely some can play the different format and send the DV via FireWire yet not output a signal via the analog route.
It's all a bit of a crapshoot, really. Best thing is to suck it and see!John Miller
enosoft - high performance tools for music and video
Home of the Enosoft DV Processor - Free for personal use!
Good news is that camcorder captures and passes PAL analog. Bad news is you need a PAL capable TV to watch it.
http://www.world-import.com/dcrpc55e.htm
Buy the cable (about $6) online and try it. You will still need the cable later when you ask around for an NTSC DV/Digital8 cam.Recommends: Kiva.org - Loans that change lives.
8mm tapes PAL with NTSC camcorder????
By igorv in forum CapturingReplies: 5Last Post: 11th Oct 2010, 13:17 -
SONY VP-7040 playing NTSC 3.58 tapes?
By steve70s in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2010, 10:10 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum CapturingReplies: 2Last Post: 17th Jan 2009, 14:36 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 21:45 -
NTSC IRE levels and DV camcorder Pass-Through capture.
By edDV in forum CapturingReplies: 84Last Post: 1st Jun 2008, 16:58
