hello everyone....when recording with my easycap capture card (360 footage) i start getting slow down usually after 30-60 seconds....the videos are still easily viewable however not as crisp as the opening 0-30 seconds of the footage.
its as if the frames per second slightly drop or my laptop is struggling to sustain the good quality over a long period.
its a USB 2.0 device and im sure i have usb 2.0 ports on my laptop...my cousin brother is going to lend me his PCMCIA USB 2.0 card...and i will try using one of the new ports to see if it make a difference.....not sure whether it will though.
i have a fujitsu siemens, intel celeron 2.53ghz...1 gig RAM....40gig HDD
im also using windows moviemaker as it appears to be the best (tried over 5 other capturing softwares).
if you have any solutions or ideas then please let me know.....thank you for reading.
Results 1 to 1 of 1
Thread: EasyCap capture card
By Howieb123 in forum Video StreamingReplies: 8Last Post: 28th Mar 2011, 10:48 -
EasyCap USB to S_Video Adapter Capture Card
By domainbug in forum ComputerReplies: 3Last Post: 7th May 2010, 20:51 -
Easycap/EZCap capture card
By kipper106 in forum CapturingReplies: 6Last Post: 12th Apr 2010, 10:18 -
Easycap Video Grabber Capture card
By Codifexda1st in forum MacReplies: 1Last Post: 24th Feb 2010, 21:28 -
Can Easycap Video Grabber Capture card USB 2.0 RCA be used to record Beta
By laslim in forum CapturingReplies: 1Last Post: 20th Sep 2008, 10:06
