I have an mpg file of a TV show that's 5Gb. Is this the correct procedure to burn it to a dual layer DVD+R?
1. Use ImgBurn to create ISO file
2. Use ImgBurn to burn the ISO onto the disc
I've never burned DVD9 before.
Thread: Burning dual layer question
Yes it's OK. It's also possible to skip step #1 and use ImgBurn to burn the files directly without creating an ISO. However, you forgot this:
0. Buy Verbatim DVD+R DL discs to use.
If you use any other type of DL disc, you are likely to have problems.
Finally, you do understand that steps only involve making a data disc and you are not making DVD format video by simply burning a 5 GB file to DL media, right? That may be exactly what you want to do, but I just want to be sure you understand that DVDs have to be authored before they are burned and you seem to be talking about simply burning a file to a data disc.
jamn89,
Thank you for the quick response. Not only did you explain it but you did it in a very easy to understand manner. Greatly appreciated.
Step 0. was done, waiting for Newegg to deliver.
Plus I do understand about data vs DVD format disc. The mpg file is in HD so I didn't want to down-rez to DVD resolution. My intended audience will just watch it on their PC.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Question on Dual Layer burning....
By ranchhand in forum DVD RippingReplies: 12Last Post: 4th Dec 2010, 16:26 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
Dual Layer Burning Help
By MMP in forum Authoring (DVD)Replies: 16Last Post: 4th Aug 2008, 14:34 -
Question about Burning an Entire DVD9 Movie to a Dual Layer
By |-Goku-| in forum DVD RippingReplies: 9Last Post: 30th Dec 2007, 18:41
Statistics
Newest guides
Latest tool updates
New media comments
