    Oct 2008
    Anyone know where I can get the files or perhaps a ftp site/ddl?
  2. Here you go
    Belight and the .dll's are quite old, there are other newer improved programs you could use - what exactly are you trying to do?
    dll.zip
    Oct 2008
    I'm trying to convert audio formats, so basically i want the output as aac.
    And thx, if anyone would know a place for a newer version I'd appreciate it.
  4. LameXP is easy to use for simple conversions , and uses the newer NeroAACEnc which is better quality (and free from Nero's site)
    http://www.nero.com/eng/downloads-nerodigital-nero-aac-codec.php
    If you want more functionality, you can use BeHappy which also accepts avisynth scripts and a lot more options
    Oct 2008
    Aiite, cool thanks for the suggestions.
    Jan 2010
    Sorry to dig up an old thread... but can someone give me the exact Lamexp setup step by step to downmix my 6 channel aac to 2 channel? I have the nero tool installed but I must be blind.... I cant see where to select stereo or 2 channel for the output..
    Thanks for any help.
