Hi guys,
I've burnt a Verbatim Dvd+R DL but it will not play on my standalone Dvd player, it works fine on my PC.
I am using ConvertXtoDVD to encode and burn the Dvd.
I think im correct in saying the media i'm using is considered to be pretty good so i'm not sure what the problem is.
Anyone give me anything to try out ie: change the settings in ConvertXtoDVD or use a different prog to burn etc
Any help greatly appreciated.
Thanks in advance.
Results 1 to 10 of 10
Did you try to book type to DVD-ROM?
I would use ImgBurn for DVD-DL.
First, you did good with your media choice!!
Next..... you used ConvertXtoDvd to burn it ??
Well, one out of two is not bad
Use ImgBurn to burn the VIDEO_TS folder to DL+R from now on.
The other issue is does your standalone support the playback of DLR media ??
Not all do.Originally a member since 2001, LONG LIVE TARAN's!!!
Thanks chaps for the replies.
Firstly i did'nt change the book type in ConvertXtoDvd as i dont know how to, any know how?
Noahtuck, i take it that was a bad choice burn wise! I shall try ImgBurn and change the booktype to ROM if i can figure out how to!
Cheers.
I can't rule out that your player simply won't play DL media. It is known to happen. If that's the case, nothing you do will work. You might post what your make and model of DVD player is in case anybody knows about problems with it. I have a friend whose DVD player will only play the first layer of DL discs and nothing more.
If your DVD player is older (3+ years) book type might be the problem. This isn't really supposed to be an issue in new players as most of them shouldn't need this to be done.
Hi jman98,
Thanks for that, i'm not sure what the make & model is of hand - i've not got access to it @ the mo but it is like 2 - 3 yrs old.
How does this book type thing work, can i change it in ImgBurn? if so how??
Quick update.
I followed Noahtuck's advice, burned with Imgburn and changed the booktype to DvD-Rom and it now works on the standalone Dvd player. I'm not sure which change has made it play but i'm very happy now!
Cheers all.
Most likely it was the booktype setting, but you should definitely only burn DVDs with ImgBurn to eliminate bad burning software as a possible cause for problems.
I also suggest the PcgEdit + ImgBurn method, to set your own layer break.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Sounds like you may have started with an AVI/Xvid. If that is is the case going to DL is probably a waste. Same your DL discs for original pristine sources.I am using ConvertXtoDVD to encode and burn the Dvd.
Burned DVD from TV and won't play in computer
By dnlowe in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Sep 2009, 17:41 -
Burned dvd won't play in standalone player
By Shotobits in forum Authoring (DVD)Replies: 12Last Post: 13th May 2008, 01:21 -
I'm not sure if my DVD player plays dual layer...
By Asaad331 in forum Newbie / General discussionsReplies: 17Last Post: 3rd Mar 2008, 16:27 -
My player won't play burned discs anymore.
By uNderdog_101 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 30th Dec 2007, 16:44 -
xvid video I burned onto cd won't play in dvd player
By dvdnewbie64 in forum Newbie / General discussionsReplies: 11Last Post: 5th May 2007, 18:45
