OK, Here is my problem.
I have HD DirecTV hooked up to my HD TV via HDMI, I have my PS 3 hooked up to my other HDMI input on the TV. I still have two open component inputs on the TV and the standard definition ones as well.
So this is what I have and need to do.
I have a cable box I would like to buy a DL DVD Recorder for. I would look to hook up my Cable Box(Not my DirecTV) through my new DVD Recorder to the TV and still be able to receive the HD Signal from my Cable Box. My main problem is, the cable box only has one audio output so I can not hook one directly to the TV and the other to the DVD Recorder.
This has been bugging me for a while and I can't seem to figure out a suggestion. I currently have a DVD Recorder, but it doesn't support DL DVD's.
Any suggestions on how to do this and what is a good DVD Recorder that records on DL DVD's is greatly appreciated!
Results 1 to 14 of 14
I think Panasonic DVDRs are one of the few that support recording to DL discs. The '08 EZ-x8 series does it best, allowing one to record straight through both layers. Last years x7 series made you close the first layer before recording to the second, not very handy for one long recording.
AFA your single audio out jack, I've found just using a Y cable on both L&R jacks works fine for audio. Video is another matter, using a Y cable on the yellow composite output makes a darker picture. You should be OK on your audio outputs splitting it once.
There are still a few good models out there for your situation which include HDMI, JVC, Pioneer, LG, Panny, Toshiba. I would stay away from minor players like no-name brands.....
I had thought about that actually, but wasn't sure if I could do that using two separate video signals. I can use the component to the TV Directly and then the S-Video to the DVD-R. I was hoping I could find a DVD-R with component in, but no such luck.Originally Posted by jjeff
Since what I will be recording is a standard signal on the cable box, I guess it would be best to use the S-Video for that.
Yeah, what I meant was one set of Audio Out(The red and white).Originally Posted by wabjxo
The only thing that stinks about running the S-Video/Composite signals back from your box to your DVDR (for the scrambled channels) is that you might not get a 16:9 recording, or it might put weird boxes around your 16:9 material. I found that with a combination of adjustments to my TV and using the zoom mode, that I can get it looking about right.
This really won't be used to copy much HD, probably all SD. Old Video Tapes and one particular SD cable channel. But now that bugs me in case I wanted to record in HD, I would like it to at least keep the WS format.
I am not sure which recorder to go with now.
I wish there was one that can record non stop on DL Discs and do WS and SD.
Yeah, I noticed that. I was hoping to find a DVDR with Component inputs and no luck at all. Wonder if that'll be in the future?Originally Posted by wabjxo
But does it do DL non stop? LOLOriginally Posted by wabjxo
A recent purchase of mine was a Sony RDR HX715 (late 2005 model) which has component in (480i only) and does straight DL, haven't tested the WS yet though.
My recorder is not recording at mode I set it at
By kevs in forum DVD & Blu-ray RecordersReplies: 5Last Post: 17th Jan 2007, 20:56 -
Enough already, I'm getting a set top DVD Recorder. help?
By Rychezilla in forum DVD & Blu-ray RecordersReplies: 6Last Post: 4th Dec 2004, 18:32 -
Smallest Set Top Recorder?
By leebo in forum DVD & Blu-ray RecordersReplies: 5Last Post: 10th Sep 2004, 13:34 -
Set-recorder owners and MovieFactory 3
By PhilipL in forum DVD & Blu-ray RecordersReplies: 19Last Post: 13th Jan 2004, 17:08 -
with a DVD-R, can I do this with a Set-Top Recorder?
By supatrupa in forum DVD & Blu-ray RecordersReplies: 1Last Post: 31st Mar 2003, 15:24
