I have an Acer Aspire Laptop 5051
it has the Pioneer DVD-RW DL DVR-K17RS drive and i want to update the firmware - some of te 8x speeds discs Iam getting are only burning at 2x which takes 30minutes a pop...
can anyone help in locating such firmware? ACER dont have any
This site has a lot of modified firmware:
http://tdb.rpc1.org/
They don't have anything for your drive at this time, but you might check back from time to time as that may change. They add firmware all the time.
You might try burning with ImgBurn (it's free) instead of whatever you are using. The 2x issue might possibly be with your burning program. It could also be the media you are using. Better quality media, which in the USA now means ONLY Verbatim and Taiyo Yuden, should burn up to the maximum speed.
thanks
its the firmware that determines the rec speed for the media - I have it on 8x but it goes at 2x
i do use cheap media but this is first time its happened in 4 years - it just mean the firmware doesnt have any record for that media so records at slowest speed to ensure it works
thanks again will look at imgburn
Nope, you have to ask acer.
*** Now that you have read me, do some other things. ***
Pioneer DVR-216 and Firmware
By dqtus in forum DVD & Blu-ray WritersReplies: 5Last Post: 27th Mar 2009, 02:26 -
Pioneer DVR 545 HX-S update firmware
By josef2010 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 17th Nov 2008, 11:25 -
Firmware disk for Pioneer DVR-533H
By jjmdtw in forum DVD & Blu-ray RecordersReplies: 7Last Post: 24th Oct 2008, 05:31 -
pioneer dvr 115/215 firmware
By stackner in forum DVD & Blu-ray WritersReplies: 1Last Post: 7th Jun 2008, 23:59 -
How do I update the firmware on my Pioneer 109 DVR?
By Boogie7910 in forum DVD & Blu-ray WritersReplies: 2Last Post: 26th Nov 2007, 04:44
Statistics
Newest guides
Latest tool updates
New media comments
