Hi, dear all.
See above:
---> http://www.fluffalopefactory.com/miyu/
MIYU: Your all-in-one solution for video subtitling and translation management on Mac OS X.
Miyu provides you the tools for scripting, timing, typesetting, and export - in one compact software package. Whether your project is foreign language epics or just home movies, Miyu can get you there with a fully featured, intuitive user interface.
Features:
Playback with real-time preview
Full screen playback
WYSIWYG Typesetting
Exclusive SnapTiming for rapid subtitle timing.
Video scrubbing with audio
Anti-aliased or aliased text rendering
Flexible subtitle positioning
Subtitle Stylesheets
Character Assignment
ScreenshotSupported Subtitle Formats:
.miyu (Miyu's native format)
.ssa (SubStationAlpha)
.srt (SubRip)
.edl
Supported Subtitle Exports:
QuickTime Video
AVI Video
QuickTime Overlay w/alpha*
DVD .spu*
DVD .stl Bitmap*
System Requirements:
MacOS X 10.3.9 or later
Quartz Extreme Capable Graphics
Free for private use, affordable for professional use.
The Miyu application itself is free and we want to keep it that way. It handles import of common formats like SSA, gives you a basic scripting and timing workflow, and exports directly to composited QuickTime movie files. So you're welcome to give it a try, do work with it, have a bit of fun and add subtitles to your iMovie and iDVD projects.
Video Performance Recommendation:
We recommend using nonlinear source video while editing and typesetting - Motion JPEG or Pixlet. We typically use MJPEG-A at half resolution, high quality audio and low quality video, for our translation work. Keyframe video will work for playback and export compositing, but, well, scrubbing back and forth in keyframe video just ain't right.
Thank you.
Best regards.
devil (johner)
http://www.fluffalopefactory.com/downloads/miyu.dmg doesn't work though...
Oh, sorry.
Try these link:
http://superdownloads.uol.com.br/redir.cfm?softid=52753
Thank you.
Best regards.
devil (johner)
Subtitling Programs for Mac
By devilcoelhodog in forum SubtitleReplies: 2Last Post: 27th Sep 2011, 17:25 -
Subtitling on the Mac
By sky captain in forum MacReplies: 2Last Post: 12th Jan 2010, 13:16 -
Dealing with VOBs, subtitles, Sizzle and Miyu
By silverspell in forum MacReplies: 4Last Post: 25th Feb 2009, 06:57 -
FAB Subtitler: Teletext and Subtitling Program
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 14th Jan 2009, 16:54 -
Submerge - Subtitling made easy in Mac OS
By devilcoelhodog in forum MacReplies: 0Last Post: 30th Nov 2008, 14:25
Statistics
Newest guides
Latest tool updates
New media comments
