Are there any free program wich plays blu-ray?
Thread: program for playing blu ray?
VLC has some support for BluRay, but it's apparently in some sort of experimental mode right now and they don't list BluRay as being fully supported. So it might work, but you shouldn't expect it to necessarily do everything a commercial BluRay player will do. I am not aware of any other free programs that can play BluRay unless maybe MPC supports it.
I've only had luck playing the individual .m2ts files with MPC Cinema and VLC player with AnyDVD HD running in the background. Use Windows Explorer to find the largest .m2ts file most times. There's the DRM to overcome, besides the unique BD structure of the disc. I gave in and got Power DVD for Blu-ray. I haven't tried the WinDVD Blu-ray player.
fyi powerdvd 7 ultra and newer are the only ones that support blu ray for cyberlink products as far as I know. There may be bluray plugins for earlier powerdvd versions though I don't know for sure.
I have no knowledge about the windvd bluray support or which versions do and don't support it. I've basically used powerdvd since I've been in the dvd world.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Best Authoring Program for Blu-Ray?
By mlong30 in forum Authoring (DVD)Replies: 2Last Post: 17th Jan 2012, 09:00 -
Q: about playing a ripped blu-ray
By raptor1015 in forum Software PlayingReplies: 1Last Post: 29th Jun 2010, 11:58 -
Playing Blu-ray on my computer
By nickelzy in forum Blu-ray RippingReplies: 10Last Post: 14th Mar 2009, 10:06 -
Playing blu-ray on PC?
By David97 in forum Newbie / General discussionsReplies: 2Last Post: 21st Feb 2009, 08:58 -
Playing HD DVD And Blu-Ray in A Pc!
By smounche in forum Software PlayingReplies: 13Last Post: 28th Mar 2008, 10:01
Statistics
Newest guides
Latest tool updates
New media comments
