Sorry if this is in the wrong section, so mods please move if so...
Anyway I am having a few problems when playing a BD that I have created in my stand alone Sony unit. I am using this guide http://brothers_grim.webs.com/bd/index.html and using a BD-RE (25GB) disc. Now I have used the disc a few times without any issues but the last few films I’ve done when I have come to play them on the Sony unit the films are very pixelated and unwatchable but when I play the disc in my PC using Power DVD its perfect.
Is it the disc or is it something else?
Results 1 to 10 of 10
Thread: Blu-ray playback issues
Anyone???
No one have any idea???
Following on from this I have now discovered that its not the disks I have been using as I have created the specific movies again on 2 new disks.
The 2 movies in question seem to be fine. The mkv files are fine and the resulting m2ts file in the STREAM folders are also fine as these play on my PC. Also the 2 disks with the movies on play perfectly in the PC.
Anyone have any ideas where the problem could lie.
- Disk
- Sony Blu Ray Player
- Files being burnt onto the disks
........overly sensitive Blu-Ray player, maybe? That's my guess, see if you can find another Blu-Ray player to test the disk on.
There is no such thing as "Idiot-Proof".........a good Idiot will get around that every time.
Thanks, thats an idea.Originally Posted by racer-x
I have actually got hold of a different version of 1 of the movies and put it on the same BD-RE and it played a treat so its either something to do with the actual files or something like the above.
I have the exact same problem when converting MKV to Blu-ray and playing them back on my Sony BDP-350 player. Although, we also have a Samsung 1500 player and the movie plays pefectly. So it must be an issue with the Sony. Reminds me of when certain players could only play DVD-R or +R.
Another problem I've encountered is for some movies they actually do play fine in the Sony, but the aspect ratio gets stretched when it shouldn't. The black horizontal bars are missing, again the Samsung plays it no problem with the correct aspect.
Any suggestions? Perhaps some settings somewhere in the convert process I could try?
Update:
I tried converting an MKV file to Blu-ray using RipBot. I burned it to a blank BD-RE disc and it played perfect is both players!
Thanks dvddemon I will try RipBot for any future problems.
Speaking of which I have just created a new BD (using method at top) and when I play in my Sony BDP-350 the picture is mirrored down the middle but it plays fine in my PC.
There has to be issues with this Sony unit. Will try RipBot for this film to find out.
TsMuxerGUI is better for authoring mkv straight to blu-ray as long as the resolution is compliant,if not i found megui best to re-encode in case the resolution wasn't compliant.
Ben Johnson-I didnt take any stereos!
M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
By messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 18:25 -
Blu Ray issues
By Jon Gallo in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2011, 12:28 -
Help w/ playback issues on blu-ray player of dvr recording
By bgart13 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Jan 2011, 23:54 -
By bgart13 in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2011, 22:02 -
Blu-Ray Playback Issues
By ixlspecific2 in forum Software PlayingReplies: 3Last Post: 14th Feb 2008, 16:07
