I am using Tmpgnc to convert DVD to VCD format after the process of DVD2AVI. Once I open the .d2v file in Tmpgnc, it works. But the audio process shows "invalid audio source".
Beside Tmpgnc, is there any other program to replace it?
Thread: Tmpgnc doesn't work
Check the troubleshooting section of this guide:
http://www.videohelp.com/oldguides/s...roubleshooting
that's because dvd2avi creates a .d2v file and a seperate audio file, you need to load both of them, choose the .d2v as your video source and the .wav as your audio source.Originally Posted by better life
or you could just install ffdshow, have it decode all media file types and just load your vob's directly into tmpgenc.
or use avisynth and frameserve your source to tmpg.
btw, why convert to vcd? why not just keep the original dvd or transcode to h264?
You might want to download EazyVCD (free). It uses DVD2AVI, TMPGENC and other programs to convert from DVD into VCD with minimum fuss. It selects parameters intelligently (aspect ratio, bitrates, etc.). It also has a built-in ripping engine, so for many DVDs, it's close to a 1-click operation to do the conversion. For some discs (e.g., Disney), you may have to use a more powerful ripping tool, and then use EazyVCD on the result.
For conversion into (X)VCD, there's hardly a better tool around; the resulting quality is about as good as VCD can get. Maybe it'll do the job for you.
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
ffmpeg doesn't work at all
By Paulo2009 in forum ffmpegX general discussionReplies: 27Last Post: 4th Aug 2009, 23:55 -
Subrip doesn't work
By mtc in forum SubtitleReplies: 7Last Post: 1st Feb 2009, 21:54 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58 -
SUPER doesn't work
By tedgrant in forum Newbie / General discussionsReplies: 6Last Post: 16th Nov 2007, 14:36
Statistics
Newest guides
Latest tool updates
New media comments
