hi,
i'm trying to burn a dvd with multiple subtitle tracks. i know how to do it with one, because there are directions for this here: http://ffmpegx.com/dvd_sub.html but there doesn't seem to be a way to do it with two. i want to be able to select french and english subtitles on the dvd once it's burned.
can anyone help? thank you!
p.s. there is help in here for extracting multiple subtitles, but not for burning them....
i rephrased the question~ bump?
I'm not aware of any Mac program capable of doing so, except for DVD Studio Pro, which may be a bit above hobbyist level ($$).
Awww....
Thanks for the input Case, I appreciate it! At least I don't have to wonder. Maybe someone else will have heard of a way but it looks like you've been here awhile so.....
Ah, well.
ffmpegX uses the command line Unix executable "dvdauthor", which may be capable of doing much more than ffmpegX uses from it. But I have never tried to use that module directly in the Terminal, nor read the documentation.
Sorry for the long delayed response, Case!
So, if ffmpegx writers haven't deciphered further uses for that command I am pretty confident that I will not get anywhere with it! I don't think I've ever even used Terminal!! I'm afraid of sacrificing my computer to my inexperience and curiosity.
Maybe you or someone else with better techie skills will have better luck, though, if the curiosity sparks you!
I don't think the author of ffmpegX wanted to put every dvdauthor function into ffmpegX. Just a basic one-subtitle could have seem enough to him. And for most people, one subtitle is enough.Originally Posted by wildgeese
The Terminal is not to be feared. The most common result of bad syntax in the Terminal is that it doesn't do anything, because the command wasn't understood. Using the Terminal usually requires reading extra documentation, as there is no graphical user interface to guide a user through the necessary steps. Command line users must have a curiosity and willingness to learn, as opposed to some point-and-click users that do not have an interest in how it all works underneath (not referring to anyone in particular).Originally Posted by wildgeese
Pretty much all command line applications have a syntax like:where the options are defined by each program, and explained in the documentation. If you've used two such programs, then others are so similar that they become easy.Code:program_name -option1 value1 -option2 value2 etc.
dvd to mkv but allow multiple sound/subtitle tracks
By chris789 in forum DVD RippingReplies: 6Last Post: 7th Feb 2012, 11:03 -
Help with MKV files with multiple audio and subtitle tracks.
By razzn in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2011, 16:59 -
DVD to h.264 -- with multiple audio and subtitle tracks
By Ozo in forum DVD RippingReplies: 9Last Post: 5th Aug 2009, 17:00 -
ffmpegX and multiple tracks
By jelockwood in forum ffmpegX general discussionReplies: 0Last Post: 30th Jul 2007, 10:55
