VideoHelp.com Forum
    Hello:
    I'm new here (this is my second post) but since I just got my Canopus ADVC 110 and Firewire card I'll probably be back often.
    I really wanted to use Windows Movie Maker to do some editing, but I'm finding that it won't play my MPEGs more than once after they're added in the timeline, and while DV-AVI's will play, they sound horrible! Some sort of tinny, metallic, low-fi distortion happening on the top end.
    I've kinda given up on it so I'm moving over to ArcSoft Showbiz, but as stated in my other question on this forum, the ArcSoft is causing static noises around the transitions once I export the MPEG, so that's why I want to see what Movie Maker can do...if I could get it to work at all!
    Thank you for your help.
  2. BuskerAlley.com zoobie's Avatar
    welcome aboard
    cap and edit as dv-avi
    Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
    Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
    You don't have to give up when you know what can and will not be accepted by windows movie maker.
    First port of call > http://www.windowsmoviemakers.net/Forums/Default.aspx
    I found that in Windows Movie Maker the video and audio sound and look bad in the timeline, but when they're exported/saved, they look and sound fine! I guess it must just give you a rough version for editing. Thanks for the tips here.
    In ArcSoft Showbiz, on the other hand, I'm finding that while MPEGs look and sound fine, AVI's look and sound bad in the program and after they're exported. Perhaps that will be another post...
  1. Windows Movie Maker Won't Open
    By kerrex_2006 in forum Computer
    Last Post: 29th Apr 2011, 03:08
  2. Windows Movie Maker crashes and won't puplish whole movie
    By LoveMyslf in forum Video Conversion
    Last Post: 12th Dec 2009, 22:19
  3. Replies: 4
    Last Post: 12th Aug 2009, 04:14
  4. i cant load my mpegs into windows movie maker
    By boomblaszy in forum Newbie / General discussions
    Last Post: 22nd Jul 2007, 12:55
