Hi! I have an LG DV388. It has PAL and NTSC modes. However the Auto or Multi mode is missing. Has anyone found a solution to this problem?
Apart from that, DV388 is a good player.
Welcome to our forums.
frnd08, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
There's no reason to even use that option. You should set the output to match the type of display you are using.
Google is your Friend
well, i have an LCD, so it supports both PAL and NTSC. so the auto mode would come in handy!
PowerDirector auto-transition? auto-audio fade?
By yic17 in forum EditingReplies: 1Last Post: 16th Mar 2011, 14:59 -
JVC HR 9600....edit mode vs auto mode for digitizing s vhs or vhs
By fuzzblaster in forum CapturingReplies: 21Last Post: 21st Jan 2011, 08:28 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 08:59 -
FLV - Multi Joiner, Multi Splitter, Multi Advert Removal
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 11th May 2009, 22:16 -
LG DV388 Auto Mode Absent
By frnd08 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 23rd Nov 2008, 06:36
Statistics
Newest guides
Latest tool updates
New media comments
