Hello, thanks very much for this program, i am on linux ubuntu jaunty 64 bits intel
and i wait the new version while the 0.17 have the problem subs, cannot start the encode from the queue mode, ( like when i try a windows version on wine) and sometime after encode it don't write Image. I am sure will many better with the new update , while at time , handbrake don't work on 64 bits intel , it install but don't start , i think are while are a version AMD 64 for handb.
Thanks for the great work ....
Results 121 to 143 of 143
here the linux version
http://www.64k.it/andres/data/autox2...264_019.tar.gz
i must admit that i have just recompiled the windows version for linux
i promise to update the software... when i have more time
BHHHDConvertToX, AutoMen, AutoMKV Developer
Thanks very much , that's help a lot, now the subtitles work, only with incrusted sub stay a problem but i think are normal , depend of source..
With the FFmpeg at end it make a false but i have not the time to can read the error.. Are possible to have a log when are a error?
i need make more test and will told you when i see a problem but so far i can use it
Thanks for your work and will very happy when you will finish it for linux when you will have time
take care and one more time thanks to have update the program
Hello,
After have make some test , i see the lavf demuxer crash when it will try to scan with it, when selectionate the encoder ffmpeg it crash too but i think are not important in linux while mencoder use it and work very good...
The problem stay with audio and subs, the selection are only one audio piste and not both: exemple english and french in movie, i selectionne both but are 2 times the same ... 2x english or 2x french
the sub seem to not work in linux , it see the sub but not add in encode at end.
For the moment are only what i have see with a few problem all the rest work perfect
Thanks for your great work and i hope to see soon a new version special for linux
take care
Message UPDATED:
After new test the lavf work with most movie but hwne it work not it crash the gui.
With mts2 the audio are not read and always problem with sub.. or when are 2 audio, only can be selectionned to work.
It will be nice when you can add the nero AAC encoder with megui profile for it.
sometime problem with preview with a few movie.
Thanks for all your effort and when you will do a perfect program you will become donation
Take care my best
Hello,
Here I`m stand:
autox264 v.18.171.1640 with x264 0.66.1114
woks fine in xp sp3 no problem with it!!
File in use: mkv, codec video H264
#Original Resolution = 960 / 528
#Aspect Ratio = 1.8182
#Frame rate =25.000
#Number of Frames = 65375
#Lenght (in seconds) = 2616
#Display Aspect Ratio = 1.8182
#Aspect Error = 2.2737
#Resized resolution = 1280 / 720
#Crop Left = 0
#Crop Top = 0
#Crop Right = 0
#Crop Bottom = 0
encoder Mencoder, no filters
queue:
"E:\Desktop\autox264\applications\mencoder.exe " -vf harddup,crop=960:528:0:0,scale=1280:720,hqdn3d=2:1 :2 -sws 2 -aspect 1.8182 -priority idle -sid 3 -of rawvideo -o autox264.h264 -nosound -ovc x264 -x264encopts bitrate=3607
ass=1:threads=auto:bframes=0:me=hex
ubq=6:turbo=2:deblock=0,0:aq_mode=1:aq_strength=1. 0
sy-rd=1.0,0.0:level=3:vbv_maxrate=10000:vbv_bufsize=1 0000:ratetol=1 "H:\utorrent downloads\Atlantis\Season 1 (HD)\S01E14 - Sanctuary (HD).MKV" -nosound
ass=2:threads=auto:bframes=0
artitions=i4x4,p8x8,b8x8:me=hex
sy-rd=1.0,0.0:level=3:vbv_maxrate=10000:vbv_bufsize=1 0000:ratetol=1:qblur=0.5 "H:\utorrent downloads\Atlantis\Season 1 (HD)\S01E14 - Sanctuary (HD).MKV"
"E:\Desktop\autox264\applications\mencoder.exe " -mc 0 -noskip -aid 0 "H:\utorrent downloads\Atlantis\Season 1 (HD)\S01E14 - Sanctuary (HD).MKV" -ovc frameno -oac faac -faacopts br=96:mpeg=4:tns
bject=2 -channels 2 -af volnorm=2 -of rawaudio -o audiox264-pid0.aac
"E:\Desktop\autox264\applications\mkvmerge.exe" -o "H:\utorrent downloads\Atlantis\Season 1 (HD)\autox264_S01E14 - Sanctuary (HD).MKV.mkv" --default-duration 0:23.976fps --aspect-ratio -1:1.8182 autox264.h264 audiox264-pid0.aac
So, Thats I wanna do:
I want to increase the resolution and the size.Nothing more, but the process went done, exept the file saved came with audio in front of video about 1.5 sec. The video is delayed.
What should I do?
I don`t wanna bother u with stupid questions, perhaps the answers is here but needed the necesarry settings.
Best regards, Lucian
you can try to "force lavf demuxer", and/or updating mencoder build
or use a more advanced application like hdconverttox
Hi all,
first of all, congratulations on this GUI and on support for Linux user.
I have downloaded both v 0.17 and v 0.19 to use on my Ubuntu 9.04. Both versions can encode the video but i cannot encode the audio.
This is may test file (avi) : Xvid-MP3
I can open and analyze it:
Setting audio codec:
On the next window i have this:
I tried to check - unceck audio PID but i get always no sound encoded.
This is the bat window during encoding:
And the queue:
Where is the mistake? Can someone help me?Code:mencoder -vf harddup,crop=608:272:62:0,scale=384:172,hqdn3d=2:1:2 -sws 2 -aspect 2.4706 -of rawvideo -o "/home/checco/Scrivania/autox264.h264" -nosound -ovc x264 -x264encopts crf=18:threads=auto:bframes=3:direct_pred=auto:me=hex:subq=6:turbo=2:frameref=3 "/home/checco/Scrivania/test.avi" MP4Box -add "/home/checco/Scrivania/autox264.h264" -fps 25.000 "/home/checco/Scrivania/test.mp4"
Really sorry for this boring post (and for may bad english
Best regards,
Checco
Hey friend I can't help much because I know almost nothing about mencoder settings but the author of this software, buzzqw , checks these forums often so he will likely reply.
Also even though the official language of this forum is english , buzzqw is also from Italy so if you feel more comfortable posting your issue in your native language I know he could help you.Donadagohvi (Cherokee for "Until we meet again")
My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
Hi (Ciao) Checco
from you image seems mplayer is unable to detect audio on your file
you have only "NONE" as audio to select
i can suggest to upgrade your mplayer build or try the AutoMen 6 (even if i doubt it can resolv your issue)
more "hope" you can got with autoffmpeg -> http://forum.videohelp.com/topic369767.html
Hi (Ciao) buzzqw,
thanks for the reply (thanks also to freebird73717
With mplayer i can play that file (test.avi) without problem
However, tomorrow i'll do some more test, with the latest build.
Regards,
Checco
Well, updated Mplayer/mencoder to latest build (i think): 2:1.0~RC3+svn20090804-0 jaunty1
Once video is imported into Autox264, i can watch the preview without problem, with the audio.
When i try to encode: video is encoded, but not the audio.
Only works using Handbrake as decoder/encoder:
If I can do some more test, please tell me
Thanks again.
Regards,
Checco
could you send me a sample of ths video ?
thanks
Sure. I tried a lot of movies. One is here: http://www.dvdloc8.com/clip.php?movieid=194&clipid=1
It's a public trailer downloaded from Digital Digest. Codec used for encoding : DIV3-MP3
AutoX264 v0.17 can analyze the video and show the preview (both video and audio), then encodes the video but not the audio.
Autox264 v.019 crashes after the "Analyze with (Mplayer)" command.
In the bat window (v 0.17), at the 5th line : "Audio stream Found"
But no audio is encoded.
The i tried an XIVD-MP3 public trailer: http://www.dvdloc8.com/clip.php?movieid=9153&clipid=4
Autox264 v0.17 again: audio stream found but not encoded.
Autox264 v0.19 as above: audio stream found but not encoded (this time no crash after analyze command)
Autox264 v0.19 with HandBrake as decoder/encoder : works, audio e video are encoded (see picture below).
The strange is that if i try the preview inside Autox264, or i try to open the movie directly with mplayer there's no problem on playback. I'm going mad
Thanks for your support.
Regards,
Checco
I have one weird problem: I was able to successfully convert several large mkvs to a smaller size, but at some point it stopped to work anymore; I mean that no output file is generated in the end and there is no error message remaining either; I have enough free space on my partitions(I suppose): 31GB on c: drive where the tool is located(I suppose that on this drive temporary files are created) and 110GB on the drive on which the file to be converted resides; the source files are large 8-13GB and the target size is 4GB since I would like to write them on DVDs single layer; anyway the conversion time takes hours, I start it usually at night, so it's out of the question to stay near the computer to observe what's happening; I suppose that something is stuck, like a temporary file that won't be deleted or a wrong setting in the GUI(but I've tried also with some preset options); I say that it could be some temporary file also, because at some point, output files where generated containing video from a previous converted file, not the intended source; afterward, no output was generated anymore; strange is also that I tried converting a smaller file 70GB to 30GB so I could stay near the computer and check and this conversion was successful.
I'm not sure if it's relevant, the 1st problem appeared after using queue mode unsuccessful.
I'm under windows XP running autox264 v.0.18.178.1757(the update was copied over v0.18.171.1640, but this was done from te very beginning, when it worked )
Please let me know any suggestions.
Thank you!
Didn't try yet, cause I have to leave home, BUT THANK YOU FOR THE FAST REPLY!Originally Posted by buzzqw
thanks for nice GUI. seems very detailed.
at present i use H264 and x264 GUI they are just basic but simple.
i can appreciate if anyone who used this tool can post input and output audio and video formats, it can take and generate.
Can it be used to Rip DVD either into mp4 or mkv?Last edited by Bonie81; 18th Apr 2010 at 20:30. Reason: addition
i tried the gui and liked it, pretty much simple once analyze with mplayer.
does it only support AAC and mp3, not AC-3 audio encoding?
hi buzzqw
many thanks for automen.
its nice and pretty simple.
tks
Great tool. Congrats =)
What GUI lib have you used for made it? QT4, wx, tcl/tk, java??
I have done some gui apps years ago using the old qt3 library.
Always it's a good idea include a language support file (plaint text), so some collaborators can translate the app to their languages and provide the lang file after done.
Congratulations one more time.
Buzz uses purebasic to code his apps.
http://www.purebasic.com/Donadagohvi (Cherokee for "Until we meet again")
this application is very outdated. i suggest to try microx264 or hdc for better x264 support
Hybrid - (windows/linux/mac), X->264/Xvid/VP8 + ac3/ogg/mp3/flac/dts/...
By Selur in forum Video ConversionReplies: 0Last Post: 8th Apr 2012, 10:41 -
Fully working GUI video converter for Linux?
By danboid in forum LinuxReplies: 17Last Post: 6th Oct 2011, 21:25 -
Any hw accelerated h.264 encoder for windows like Elgato turbo.264 HD
By chicken264 in forum Video ConversionReplies: 3Last Post: 14th Apr 2011, 16:22 -
mkvextract gui not extracting h.264 viddeo stream
By kurian in forum Video ConversionReplies: 13Last Post: 21st Feb 2011, 11:14 -
DeVeDe - easy, batch capable video to DVD Linux/UN*X GUI
By danboid in forum LinuxReplies: 1Last Post: 23rd Oct 2008, 18:48
