Hello my friends.
I have a Dvd Philips DVP 5980k that has USB port . I had already plug in this USB port, a standart pen drive and also an external USB 160gb Hard drive I have. it worked fine!
My question is... Am I able to connect this DVD front panel USB port to my PCs USB port and access the files located in my PCs hard disk?
How?
Thxs
No, USB uses a Host/Client type of connection, you can't hookup two hosts or two clients together. The player's port is a host and the PC's port is a host.
I'm pretty sure that won't work. In order to "stream" directly from the pc you will need a networkable dvd player.
I belive Oppo makes a few that have a network port on them. As always you can stream video to either a ps3 or an xbox 360. I think you can even use orb on the wii for web streaming though I would not recommend the wii as a media player since its very limited in its functionality.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
question about why some avi's will not play from DVD USB port
By jimdagys in forum DVD & Blu-ray PlayersReplies: 4Last Post: 5th Nov 2007, 06:33 -
DVD player with USB port
By Scooby Doo 12345 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Oct 2007, 09:35 -
Whick dvd player with usb port can play rmvb file?
By haitang in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Jun 2007, 01:31 -
USB 2.0 port on Canon A620 camera compatible with USB port on PB 867 MHz
By tab75-13 in forum MacReplies: 5Last Post: 24th Feb 2006, 18:48 -
Any DVD player controlled via Serial Port/USB?
By realmexican in forum DVD & Blu-ray PlayersReplies: 0Last Post: 9th Apr 2004, 00:41
Statistics
Newest guides
Latest tool updates
New media comments
