I have got a .mov file that I want to edit, what program can edit it preferably without re-encoding it? I would like to keep the file as an .mov file.
Also I have got .ifo/.vob from dvd decrypter and I would like to edit it before I convert it to xvid using autogk, is there any program that will do this, again preferably without re-encoding the .ifo/.vob file.
To your second question. You will have to be a little more specific as to what you mean by editing .ifo/.vob.
There is lots of software to do all kind of things, but it all depends on editing you require.
1. Try MPeg streamclip or quicktime pro.
2. DVD shrink in the reauthoring mode.
I want to cut parts of both videos.Originally Posted by tinker
Does mpeg streamclip recode the video after editingOriginally Posted by Baldrick
I have look looked at the guides for DVD shrink on this website, but I can't see how to edit out commercials in the middle of the video. It looks like you can only cut parts out at the beginning or the end, can anyone confirm this?
You can by using VOBMerge or DOS cmd "copy /b VTS_01_1.VOB + VTS_01_2.VOB NEW.VOB" after you have done your re-authoring in DVDShrink by adding your video title multiple times to the left pane for as many segments as you want cut and setting the start/end for each one seperately. Just maybe Baldrick has time to add this info to his nice Oct 27 guide ;]. Also think that guides description should include Tools used: DVDFab HD Decrypter so it shows for that tools page also.
If you want to do more complex editing in mpeg2, look at Womble's Mpeg Video Wizard DVD. It is not free, but good editing software. You can do any cut anywhere you want and add transition to the cuts, if needed.
VOB files to a DVD-IFO file?
By verdikt in forum Authoring (DVD)Replies: 4Last Post: 26th May 2011, 13:03 -
recreating vob ifo files
By krohm in forum Authoring (DVD)Replies: 25Last Post: 15th Jun 2009, 05:27 -
What should i do with vob/ifo files?
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 2Last Post: 16th Dec 2008, 01:26 -
How are ifo files created with only vob files?
By Han Solo1 in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2008, 13:07 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 13:38
