  1. Member ZIL150's Avatar
    I can not record (save to hard drive) videos from www.MyOutdoorTV.com . I try MS internet explorer, Mozilla, Opera, Chrome with some software recomended in "video streaming recording" (VDownloader, URLsnooper, VideoCasheView ...), but get nothing.
    May be someone know how to do that ?
    I tested replay media capture, and can confirm it works on those clips, unfortunately it's not free
  3. Member ZIL150's Avatar
    2 poisondeathray:
    I did test ReplayMediaCatcher today morning (as trial version), but I can catch only *.tmp files if "Web Stream Dumper" plugin is activated.
    Maybe I miss something while trying to record, or use wrong setting.
    How exactly you do that?
    Hello,
    I have the retail version so it might be a bit different.
    I start replaymediacapture first, and start recording
    Then I go to the webpage video and it will start automatically
    Make sure you are using the most recent version with all plugins (I'm using 3.01)
    Here is a sample that I downloaded from the dog page
    http://www.myoutdoortv.com/main-homepages/scott-linden-sporting-dogs.html
    tiles%20with%20categories(2).flv
    EDIT: for some reason that url is screwed up I'll upload to another site, just a sec
    http://www.megaupload.com/?d=7ENU2JLX
    I have "capture flash RTMP stream" "RTSP,MMS streams" and "HTTP media streams" checked off in the settings, I didn't even have the "web stream dumper" plugin checkmarked at the time
    Also it's not a .tmp file, it's an .flv file that streams. And if you are on Vista, perhaps try running as administrator and disabling UAC, or perhaps it's a firewall setting ??
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    poisontdeathray: () in the filename wont work on this server.
    Or maybe http://forum.videohelp.com/images/guides/p1909738/tiles%20with%20categories(2).flv
    edit: Yep, the above link works. .
    Good to know! thx master Baldrick!
