VideoHelp.com Forum
  1. Member MOVIEGEEK's Avatar
    Sony Pictures halts the release of streamed media with Xbox360 users that have a Netflix subscription.
    http://www.electronichouse.com/artic...from_xbox_360/
    Sounds pretty lame to me.
  2. Member MozartMan's Avatar
    Did you forget what Toshiba, Microsoft, and Paramount did with Transformers movie when we had war between HD-DVD and Blu-ray?
  3. Member MOVIEGEEK's Avatar
    No but this is like Sony refusing to let their DVD's work on a Toshiba DVD player.
    Apples and oranges my friend.
  4. Member yoda313's Avatar
    Close but netflix does have other distribution outlets besides the 360.
    This is bad for 360 users who are netflix junkies. BUT its not the same as hddvd because that was an all or nothing type of thing. With netflix you can still stream to the pc or get a physical disc. This is bad for reducing the conveninece to a console of course.
    I guess we shouldn't be suprised Sony would be back to its strong arm tactics.
    Sony should let playstation 3 and xbox stream the netflix content. I own PS3 and can't stream anything netflix. This kind of attitude from corporations promotes piracy.
  6. Member edDV's Avatar
    And I was considering a PS3 as a UPnP player. I'll look elsewhere.
    http://www.kiva.org/about
  7. Member yoda313's Avatar
    @eddv???
    This article is referring to the 360 not the ps3.
    And actually since the ps3 can handle m2ts in some fashion and has better mp4 support there is nothing wrong with its multimedia capabilites.
    Granted you have the fat32 limit if you hook up external harddrives. Or you could upgrade the internal harddrive without voiding the warranty from what I am told. However you should check with SONY before doing that just to be on the safe side.
    Although with that new WD Media player that may be a more attractive option. Since that does support NTFS that may be the way to go. DLINK, or is it LINKSYS? THere is a dual harddrive UPNP network adapter you can get for under 200.00. I don't know its multimedia capability but the fact it supports two harddrives is impressive.
    By the way, just curious what are you looking for in a upnp player? Do you need it to be wireless? There are wireless N players from Dlink and Linksys now that claim high def support. Also of course there is the SLINGBOX series.
  8. Member edDV's Avatar
    My point was not XBox vs. PS3 but Sony vs. less draconian UPnP media player supplier. Games are secondary. The PC is an adequate game platform for me. I'm concerned about committing the living room to Blu-Ray and Sony. Alternative is to bypass Blu-Ray for another HD strategy.
    On Black Friday I purchased a large wall/floor drill that I'll use to run Cat6 Ethernet to living room and all bedrooms. Cables will meet at a central patch panel - gigabit switch in the basement. An existing wireless G router will service the laptops.
  1. Tearing my hair out trying to convert HD movies for Xbox 360
    By gers1978 in forum Video Conversion
    Last Post: 4th Oct 2011, 06:30
  2. Replies: 18
    Last Post: 3rd Apr 2010, 06:19
  3. Replies: 1
    Last Post: 3rd Mar 2010, 04:49
  4. Playing full movies over Xbox 360 from HD
    By Cpyder in forum Video Conversion
    Last Post: 30th Jul 2009, 19:23
  5. Replies: 0
    Last Post: 25th May 2008, 23:58
